[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Originally posted by v3n0m3n0My goal is to improve cooling with minimum ingeration into housing. I'm going to swap original heatsink with 40x40x11 using thermal adhesion. Hope this will help.
I personally ended up with this 40x40x10 fan at 5V and now the temps rarely go past 40C when watching 4K/60fps content. Super quiet setup btw:
Magendanz, do you plan to release an update of this fantastic rom (based on Vorke) with support of L1? This is the only thing I miss from your previous releases.
#396.1Guest commented13 February 2018, 02:16Editing a commentI'm having trouble getting the Widevine L1 support up and running. Specifically, the OP-TEE kernel modules are missing from the boot partition. (The insmod calls are in init.amlogic.board.rc, but the files aren't where they're supposed to be. If I add the files back in, it hangs on the logo screen.) So many of these new M8S PRO units are shipping with Widevine L1, I'm reluctant to switch over to a new ROM that won't support it.
What's also aggravating the situation is that I can't get an L1 update for any of my M8S PRO boxes from either online retailer, meaning I have to test on my M8S PRO L...which doesn't support the new bootloader and doesn't have a reset switch. This makes the troubleshooting take considerably longer than it should.
SO @Magendaz u are saying creating a firmware based on Vorke Z6 firmware will never retain the L1 in M8s Pro?
Well, you won't lose L1 by flashing the Shiningworth firmware, but it can't take advantage of Widevine L1 until we do some major work because it doesn't even have the trusted execution environment (TEE) working yet. If you flash back to a ROM based on the original VideoStrong firmware, it will work again.
Hi Sorry if this question will be asked but, i have install this firmware and after all reboot or power off language change to chinesse. Impossible to memorize other language i have try to look in build.prop i not found language... i have try to add :- ro.product.locale.language=FR
- ro.product.locale.region=FR
I have try to reset factory, same problem, format cache / davlik same problem, full reinstall with Burn Card Maker same problem...
How to solve ??
Thank you in advance for help.
edit : i have maybe find a solution in HDMI CEC i have desactived « automatique Language » now after reboot language is goodLast edited by Deki; 18 February 2018, 21:42.
hi magendanz ! hope youre doing well ! i really tried more that 4 rom and it freeze at 4 or 2 % dont know why the burn backage is not the best for my tv box ! it a : Mecool M8S PRO Amlogic S912 3GB DDR4 RAM 16GB ROM TV Box
any solution please i am working for it 3 days now and nothing ! i need the update because tv center crached and the box seems bad
Hello cant you help im update my tvbox Mecool M8S Pro whit this update_Nexus_M8S_TVStock_NHG47L-20180202.zip firmware but playstore is not good and menu like a Android TV is not Good i want to install nano Nexus cant you help me how to downgrade my TV Box
Originally posted by achraf View Posthi magendanz ! hope youre doing well ! i really tried more that 4 rom and it freeze at 4 or 2 % dont know why the burn backage is not the best for my tv box ! it a : Mecool M8S PRO Amlogic S912 3GB DDR4 RAM 16GB ROM TV Box
Just leaving my experience already installed ROMs of other devices that are compatible with my model (q20x) and none of them came to lock, at worst the screen was black and white, it was difficult to access recovery mode but I did.
I always use a 4GB memory card to place the file using the SD Burn Card Maker tool. Safe with a toothpick or tool remove chip drawer and the procedure starts.
For download the SD Burn Card Maker click here.
Originally posted by n3v3rm1nd View PostHello cant you help im update my tvbox Mecool M8S Pro whit this update_Nexus_M8S_TVStock_NHG47L-20180202.zip firmware but playstore is not good and menu like a Android TV is not Good i want to install nano Nexus cant you help me how to downgrade my TV Box
There are currently 1839 users online. 1 members and 1838 guests.
