[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Originally posted by Bllq21 View PostAfter almost FOUR MONTHS my box finally came
I don't like the firmware but I don't know if this one works for my box and if I might lose some functions
mine has 2gb of Ram and 15 of Storage
Can I use this ROM?
>>> edited for fix on comment. <<<
Originally posted by Novato View Post
Only the risk of losing your device ... There are some drives of this TV box that came with a bad chip, in case you change the firmware may present a serious problem ... Read the red lines of this topic to know more, in it you can get the correct firmware ATV for your device ... And about your device I say to you, this is the "Pro +" model, so everything about your device will be in: AMLogic based TV Players> S905X players> Other AML S905x> firmware - ROMs - Tools> here.
it has the firmware 20171128.111200.V0928 but at least my box hasn't crashed and works fine
but that Stock ROM it's terrible, I can't even use Netflix because I have it plugged via AV Output (cvbs)
I'll try to remove (and add) everything I can to make it a little less painful
I'm sorry... You need back to stock OEM firmware 321 Kernel... You can return as follows:
1 ° Using BurnSDCardMaker choose the OEM Firmware with the latest 619 final.
2 ° Flash normally, simply insert the card and hold reset button until the update starts.
3 ° Then using BurnSDCardMaker choose the OEM Firmware with 321 final.
4 ° Flash normally, just insert the card and hold reset button until the update starts.
5 ° Now you have the OEM firmware you need, if you want, you can install the ATV based on 321 firmware the path is open.
Perhaps there is an easier way for this, but these steps I have spoken of are drowngrades that are allowed to errors.
and thank a lot
Unfortunately my Box has that bad chip I realized until I opened it to do the reset
I'll try to remove (and add) everything I can to make it a little less painfulOriginally posted by Bllq21 View Post
am looking for a replacement for my faulty mecool m8s pro+ s905x (bad batch of emmc) would you recommend still buying this version s912 or another box for example? many thanks.
Would anyone know if this ATV firmware can be used on the Wechip Z69? I just got a M8S pro 3x32 at a swapmeet today for 10.00 US.. Flashed it with your firmware, So far working great! live channels, playstore, netflix,etc.. Only Chromecast is not working.. Small price to pay for a otherwise fairly stable rom.
I also own a Z69 3x32 amlogic 905X box running 7.1.1 build is very similar to M8S pro factory rom. Do you have a rom in your collection for this model? and is there a list of all the ATV roms you have created? Thanks!!
There are currently 3716 users online. 0 members and 3716 guests.
