Can you tell me if this ROM it is for the meccol m8s pro of 3gb of ram ddr4 and EMMC Nand Flash "ROM" of 16GB?
[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Exactly, I agree on size and number with both of you! It's much more stable, and most bugs have been fixed, one or the other with the Google app (sometimes it stops), but it's way better than the previous version. Many thanks Guest for your help with the OTA update! I just moved from M8S_PRO to M8SPRO at the build.prop line you indicated and the update was perfect. My only real frustration is this one of the reboot device when erasing the screen, I am accustomed to other box in which erasing the screen was just deep sleep. I'm pretty sure that this bug not because of its firmware modification, I tested a "Stock" and also had it. It seems that the latest builds released by "Mecool" are coming with this bug. It would be great if I had the sleep options removed from the device. Another even more annoying thing is that when I am using the directional keys quickly device clears the screen and restarts when pressing Power Button. If you removed the possibility of deep sleep, that would be great.
Originally posted by Novato View PostSee how "deep sleep" happens or the standby mode for me ... I click the left and down arrow keys several times and this causes the device to turn off the screen. Yes, I know, it's a very ridiculous mistake, I did not extend it because it happens. This caused me some frustration..
Not something accurate, sometimes I'm playing or zapping the menus and the screen turns off.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Magendanz View PostWhen the 20171005 build was first released, it had the wrong device code. This error was quickly corrected in a subsequent rolling update, but you'll need to make the correction yourself. (The check is critical so that you don't install the update on the M8S Pro L, which will brick the box.)
Just install a root file explorer like EFS File Explorer and modify the build.prop value for "ro.product.device" from "M8S_Pro" to "M8SPro". After that, the update should pass environment checks.
Alternatively, you can just flash the burn package (or comment out the check in the updater-script).
If you're not comfortable making changes to the bujld.prop on a rooted device, just unpack the OTA update and remove the following lines from updater-script (buried in META-INF):
(file_getprop("/system/build.prop", "ro.product.device") == "M8SPRO") ||
abort("E3004: This update package is intended only for the M8S Pro.");
Once that is gone, it won't care what device it's installing on. (Note that this is very dangerous, which is why I'm reluctant to post the modified .zip file.)
When you repack as a .zip, it will no longer be signed with the platform key. Just install in TWRP and make sure the Zip Signature Verification option isn't checked.Last edited by Guest; 05 November 2017, 22:46.
It is a defective remote. I have 3 of these Mecool boxes, with 3 identical remotes. One remote from my original Mecool M8S Pro Plus, has this issue, but not the other two.
Guest
Has anyone experimented with different settings for config_shortPressOnPowerBehavior? These config settings are defined here and compiled into framework-res.apk.
<!-- Control the behavior when the user short presses the power button.
0 - Nothing
1 - Go to sleep (doze)
2 - Really go to sleep (don't doze)
3 - Really go to sleep and go home (don't doze)
4 - Go to home
5 - Dismiss IME if shown. Otherwise go to home
<integer name="config_shortPressOnPowerBehavior">1</integer>
You could set this to "0", "4" or "5" to prevent going into sleep via Power button short press. The deeper sleep options will have slower wake, but might work around the reboot bug.
Originally posted by Magendanz View PostHas anyone experimented with different settings for config_shortPressOnPowerBehavior? These config settings are defined here and compiled into framework-res.apk.
0 - Nothing
4 - Go to home
Maybe you're right, after posting here I changed Powerkey's default "sleep now" to "shutdown" and when I press the directional buttons on the remote control in some sequence, instead of entering "sleep now" it just shuts off as if I had chosen to hang up. In other words, something causes the directional keys on my control to turn on Powerkey.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 2284 users online. 1 members and 2283 guests.
