Where can I find the download page in order to manually check the latest builds?
[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Originally posted by Magendanz View PostMight be time to consider using Mask ROM mode to reset the eMMC. Do we know the pins to short on this board?
Have reflashed with stock and managed to root it.
Having tried to flash the ROM via OTA update and even the image using USB burning tool I can conform this ROM does not work on the Mecool KM8 P s912 even though they share the same board.
I would have dearly loved to have the Android TV launcher. Is there any way you could compile a ROM to test Magendanz?
All the stock roms and TWRP are on the following page:
Taken from http://4pda.ru/forum/lofiversion/ind...07465-440.html
I own the Mecool M8s Pro S912. When I connect the device to the TV, the toothpick trick does let it go into recovery.
When I try to do the same thing on my PC with the USB Burning tool....nothing happens.
It look likes the device isn't recognised at all. Tried everything.
Is there another way to change recovery and get root access ?
Guest
Originally posted by dkoek View PostWhen I try to do the same thing on my PC with the USB Burning tool....nothing happens.
Originally posted by dkoek View PostIs there another way to change recovery and get root access ?
Magendanz, that is what I thought, but can't get a paper clip into the hole. Even tried a very, very thin needle, but will not go into the hole, guess I will have to open the case and take a look.......
Thanks for confirming I am looking at the correct hole.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I opened it up, but unfortunately, the reset button is defective, it will not be depressed........MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Any chance they moved it to the M8S Pro+ location? http://freaktab.com/forum/tv-player-...688#post660688
No, I disassembled the box and removed the mother board, the switch is there, but not sure how to say it, appears to be stuck in. But if it was stuck in, then it would not boot, I am thinking. The back side where the switch is soldered, is very congested with very tiny solder joints, making it almost impossible for me to replace the switch.
It is the 3/16 gig box, and my plan was to dual boot into Linux, but without a working reset button, that will not be possible. So, now I will have to decide to install your awesome, mod or leave it as it is for possible OTA updates......... Once I go to your mod, I guess I will be stuck, unless I can install Ubuntu from TWRP, that I believe you have included into your ROM.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Guest
Well, using the OTA updates you can revert to OEM stock or install new custom ROM releases. You just need to enter TWRP recovery by typing "reboot recovery" in the Terminal app. No reset switch needed. Also, you should be able to flash full Amlogic burn packages (img files) from SD card with Bootcardmaker.
There are currently 2098 users online. 0 members and 2098 guests.
