[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Guest
Originally posted by j0rdie View PostTried it nothing happened box not booting...
Hi Magendanz,
Well, after buying the usb cable and flash the M8s Pro, that work like a charm (and the freeze problem is, apparently, a TV-Hdmi problem, not a mecool prob)
Just a question, i have flashed the Stock file (after the TvStock file) cause i use the TvBox more as an Android Tablet than a TvBox, but i don't have see in "Parameters" how to change the "screen resolution" and "screen size" (like they exist in the TvStock rom)
Any way to acces to this parameters ? (maybe with a command line in terminal ?)
Guest
Originally posted by bearimprint View Post...but i don't have see in "Parameters" how to change the "screen resolution" and "screen size" (like they exist in the TvStock rom)
Hello,
Since I bought the mecool m8s pro, as soon as I cut the device then I restart it, it always blocks me on the main page.
I installed the Nexus and I have the same problem.
Is there a solution for me to properly reinstall the firmware Mecool or Nexus.
Thank you for your help
When the device is started, it remains blocked on the Nexus image
Guest
Originally posted by atchoum View PostWhen the device is started, it remains blocked on the Nexus image
Originally posted by Magendanz View PostOh, that's a different beast entirely. If it's happening with both stock rom and my custom ROM, you may have some bad hardware. Are you flashing the burn package (.img file) or the OTA update (.zip file)?
i strange i installed the firmware M8S_PRO+-20170715.093046.V0321-signed (1).zip
Guest
Thank u Magendaz, rocking my M8S Pro since 2 days with your ROM, I didn't backup my original stock ROM but it doesn't matter...I don't think I will ever go back! Awesome ROM! Just a few questions:
1- About Prime Video. In stock rom, I could find the app on play store, although we all know it was limited to 480p. In this ROM however not only I don't find it on playstore (I have to downloaded it from apkmirror) but as soon I start a movie, goes error (although I can see a few initial frames, weird). Is there some way to fix it? I understand its a useless question since even if there is a way, I'll be stuck in 480p anyway...is there a way to get 1080p in stock or TV rom anyway?
2- am I dumb or double tap on home screen for recent apps doesn't work?
3- what about future builds? How to flash them? In stock ROM, I went to "local update" menu...in here I don't see it. Or should I use twrp instead?
4- too bad for the broken Chromecast streaming. R u going to fix it?Last edited by DanyXP; 13 August 2017, 12:03.
You installed a ROM for the M8S Pro+ (Amlogic S905X) on the M8S Pro (Amlogic S912)? I wouldn't think it would let you do that, but that would explain your trouble.
there are possibility the recovery my box, it's out now
i have a big problem now.
look for this thread*M8S Pro USB IMG M8S_PRO-NMF26Q-20170524.163713.V0321.img
That is the original stock rom for the M8s pro with S912.
Actually there's a newer build (M8S_PRO-NMF26Q-20170707.094011.V0321.img) available now here: http://freaktab.org/078d65b334fbcfc2
There are currently 2763 users online. 1 members and 2762 guests.
