[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Finally my m8s pro arrived !!! LOL .. after months of wait, I now have him in hands! the question which is now is then maybe this ROM is compatible with my model? So...Guest my device is a m8s pro 2gb of Ram and 16gb storage, he is compatible? has not updated for latest version, I can just install as update OTA playing your firmware for card memory?
Thanks, Magendanz , I did update OTA and it went well. I loved ROM, congratulations! Just had a few problems that made me a little sad, for example, when I click on the Power button, instead of just turning the screen off, the device turns off, for example, the device deletes the screen as it should, but when I press the button to light I realize that it is being initiated. Holding the Back button shows "Google Stoped" message, but the Google button on the screen returns. However the worst is that my GameSir control does not work the buttons after connected via Bluetooth, it is working fine, but via Bluetooth it is impossible to use it, it only works with Dogle Wi-Fi or USB cable.
Yes, the standby recovery issue is listed in the Known Issues of the release notes. I'm hoping that VideoStrong will fix it with their next release. The long press on the back button is because I set config_longPressOnBackBehavior to 1, which should bring up voice assist. I understand now that option is only available for watches, and so that's why the Google app crashes. I'll remove that "feature" with the next release.
Hi, I'm here again, I wonder if it's possible to go back to the original ROM by putting the .IMG file (available for download) on the memory card and flashing through TWRP, or just passing through the PC with the flash tool? I would also like to know if I would have an OTA update to return to stock.
Originally posted by Roman8d5 View PostGood evening, M8S Pro TVStock Nexus ROM (Android TV 7.1) does not work Bluetooth ?, does not find Rapoo A3020
Guest
Changelog (20171103):- Updated to latest M8S Pro OEM firmware (20171030.162112.V0619)
- Removed attempt to launch voice assist on Back button long press. (only valid for watches)
- Latest build from Open GApps (20171103)
- TVStock Variant: BURN PACKAGE (999MB IMG file), OTA UPDATE (526MB ZIP file)
- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Guest
When the 20171005 build was first released, it had the wrong device code. This error was quickly corrected in a subsequent rolling update, but you'll need to make the correction yourself. (The check is critical so that you don't install the update on the M8S Pro L, which will brick the box.)
Just install a root file explorer like EFS File Explorer and modify the build.prop value for "ro.product.device" from "M8S_Pro" to "M8SPro". After that, the update should pass environment checks.
Alternatively, you can just flash the burn package (or comment out the check in the updater-script).
There are currently 2016 users online. 3 members and 2013 guests.
