thanks and sorry for my english.
[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
hello. i am new in this android boxes, i bought a m8s pro box 3 gb ram ddr4, with wild lvl1. the firmware is not good on this box, when i turn off and turn on later letters are on chine. i change on english but change everythime when i turn off box. so i won to install this rom, can i install with ota this rom, and new update to get with ota or must download new rom and install again.
Good morning, Magendanz.
First of all congratulations for the development of ROM
I have 2 doubts:
I made the firmware update via OTA update, I would like to know how I can continue the later updates since the OTA update is no longer available on Android TV.
Regarding Bluetooth .. I felt a bit of slowness in the response of the commands when paired to SNES 8bitdo control. would be some configuration problem?
Thank you for your attention.
The newer versions of the Nexus custom ROMs for this device have an update app accessible from Settings->About->System update that will allow you to install incremental updates without needing to reboot to TWRP recovery. Until you get one of those newer versions, though, you'll need to install in TWRP, Burn Card Maker, or USB Burning Tool.
Originally posted by Magendanz View PostNote: If you were one of the lucky folks to receive an M8S Pro with Widevine L1, I'd be interested to hear if this ROM allows you to run Netflix.
Changelog (20171116):- Updated to latest M8S Pro L OEM firmware (20171109.180937.V0928)
- Added additional option (Reboot & Sleep) to global action menu that displays when you press and hold the Power button.
- Latest build from Open GApps (20171116)
- TVStock Variant: BURN PACKAGE (996MB IMG file), OTA UPDATE (526MB ZIP file)
Try the archive site here: http://freaktab.org/3~f
OneDrive has just been flaky lately, but it's still way faster than the archive site.
Hello,
i have a problem Ith my mecool m8s pro, when i turn off my tv, the box mecool going to sleep but when i turn on my tv, the box don't wake up.
the hdmi cec is activated and i haven't tne same problem with my nexbox a95x.
edit: sorry i have a m8s pro + , my question is not the good forumLast edited by nonoengironde; 02 December 2017, 12:36.
Dear Guest , got new firmware for M8s Pro base on latest M8S Pro L OEM firmware 20171127.165619.V0928
That's not based on the M8S Pro L firmware, that IS the M8S Pro L firmware. It's been posted for a while, and we just received a 20171208.110230.V0928 release for that box. Frankly, that new version isn't worth passing on, since it just removes support for sleep, the console service and Google Cast. Not a step forward, in my opinion.
Hi, I would like to share a bug happening with my Mecool TV Box ...
Whenever I am using the remote control, and repeatedly pressing the right directional key ◀ the appliance switches off. The most interesting thing is that if I repeat the process even with the device turned off, it simply starts on as if I had pressed the power key. I wonder if this is an OEM Firmware bug or only all Mecool remotes are defective.
Originally posted by mirbg View PostMine is the same. Known bug with the default remote.
Buy any wifi airmouse and you'll be fine.
Hi, I'm going to need help from you ... I'll try to explain exactly what happened to my Mecool M8S Pro ... Yesterday I changed some files in / data / mediadrm and Netflix stopped working, even though I left everything as it was before (files, permissions and etc), I thought that with an apdate_ota via TWRP + Wipe Cache / Dalvik would work but the app continued with the same problem ... Network connection error. So I had the stupid idea of doing Wipe System on TWRP, and installing OTA, the errors started there, it did not work, so I tried to install a previous Firmware (Kernel 619) that was on the card, it started fine, o X (Finishing that the Operation Failed) ... Currently the device turns on the Blue LED but does not show image, I can not anymore by the card. What will happen to my TV Box? How do I repair it? I need a complete procedure, I am totally lay about Mask ROM Mode, if possible send me photos of which pins to make short circuit.
Help me Guest z ....
Thanks Guest, I managed to solve Brick still yesterday, but the end of the day was so tiring and I ended up not reporting here.
I do not know what exactly caused the flash interrupt through SDcard on the first try, but that made things difficult for me.
Well, now that I've managed to fix the problem I'll explain what I did to get out of the brick:- 1° I have previously backed up my other M8S Pro directly to the memory card.
- 2° I copied the recovery.img (TWRP) to the root of the memory card and placed it in the damaged device.
- 3° Turn on the appliance by pressing the reset button on the bottom center until the TWRP starts.
- 4° Restore the partitions to Logo, Boot, Recovery, Data, Cache and System, but the Data partition was unable to be mounted.
- 5° Using BurnSDCardMaker I formatted the sdcard with the last OEM Firmware for the M8S Pro, the version was on 10/30.
- 6° Then I put it in the device and flash started without any problem.
Fortunately I got my little device back! : D Finally some final considerations that are very important ...
My device still had blue LED, I deleted the system partition by TWRP and tried to flash by flashable sdcard.
Before backing up the partitions I installed AndroidTV on my other M8S Pro in the latest version.
Sorry my bad english, translated by Google! xDLast edited by Novato; 10 December 2017, 19:15.
There are currently 1554 users online. 2 members and 1552 guests.
