[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Originally posted by Magendanz View PostAs promised, here's a build of the TVStock Nexus ROM for M8S PRO based on the Shiningworth firmware. Basically, it's the same as the ones I created for the Vorke Z6 and Beelink GT1, but I've updated the device tree so that Ethernet now works correctly.
Burn Package: Nexus_M8S_TVStock_NHG47L-20180119.img
This has a bunch of new features and fixes that we haven't seen yet from VideoStrong. For starters,
- Quick (2-3 sec) resume from sleep with preserved user state
- Auto framerate settings (3 modes)
- Superuser root setting
- Hover at top edge of screen to show status bar
- Drag up from bottom of screen to show navigation bar
- HDR and SDR settings
- Additional Dolby/DTS/Digital audio settings
If the consensus is that this is better than the ones based on the official OEM stock firmware from Videostrong, we may move to this new foundation permanently. For now, though, it's just a trial. What do you think?
He keeps his promises and FTF members are grateful. TU for all your hard work(of which I have no clue what it entails). Let's give it up, guys...
This shiningworth ROM sounds like it has a good few benefits over the videostrong based one I'm currently using. What are the negatives with it? Is Bluetooth connectivity a problem in general or is it just with Bluetooth audio streaming? Would widevine L1 support be preserved for those boxes that have it?
The BT audio stuttering problem is still an issue with the Shiningworth firmware on this wireless chipset, but I'd say we're close to a fix on that. Widevine L1 will be preserved (assuming you don't check Erase All, Force Erase All or Overwrite Key). I haven't been able to check Netflix playback, since I don't have a box with L1...at least not yet.
Thanks Magendanz. Are the libraries present in this rom that enable Netflix ATV to work at 1080p (for those with WV L1)? I think the ROM I'm currently using was one you had built using the M8S Pro L firmware with those libraries intact (and it's been a really good, stable ROM ).
I'll try and pry the box away from everyone in the house to test this new shiningworth ROM but will have to revert back as Bluetooth audio is used quite often
So we cant install this firmware using SD card making tool? Since I had no success in getting my device recognized in USB burning tool
Should we select erase bootloader?Last edited by ashoktvm; 26 January 2018, 06:31.
I am able to make it recognize in usb burning tool. So in that we should select erase flash and normal erase underneath it, erase bootloader and reset after sucess? Is these the options to be selected?
It changed to L3 after using the same procedure u told Magendaz.
It got back L1 status after flashing stock firmware. @Magendaz can you take a look at why the status changes to L3 in this firmwareLast edited by ashoktvm; 26 January 2018, 15:45.
Guest
[QUOTE=ashoktvm;n705014]It changed to L3 after using the same procedure u told Magendaz./QUOTE]
So, ota is up
Rerun the WV burn pkg. When rebooted? Or.. Isit possible to load at the same time via twrp?
OR.. Am I likely to have an addressing /fw conflict?
Isn't it a one off build?
Guest if u want to test with any other method. I can do it for you. Just update me what I have to do
Or is the Shiningworth firmware will never be able to make the Mecool M8s pro which have L1 retain it?Last edited by ashoktvm; 27 January 2018, 05:28.
Originally posted by ashoktvm View PostGuest if u want to test with any other method. I can do it for you. Just update me what I have to do
Any way to make the miracast and airpin and DLNA app work with this ATV rom which comes default in mecool rom?Last edited by ashoktvm; 27 January 2018, 15:04.
There are currently 2302 users online. 0 members and 2302 guests.
