[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Originally posted by ashoktvm View Post
Also while trying to cast video I am getting unable to cast display using ATV firmware based on M8s pro L firmware
Any way to make the miracast and airpin and DLNA app work with this ATV rom which comes default in mecool rom?
Guest , I couldn't install your new ROM, the one based on shiningworth, it told me that this ROM is for amlogic q20 board only. Is it not suitable for my m8s pro 3/32?
Guest
Here's another revision of our little experiment building Nexus TVStock for the M8S PRO on the Shiningworth All-in-One firmware:
Burn Package: Nexus_M8S_TVStock_NHG47L-20180202.img
OTA Update: update_Nexus_M8S_TVStock_NHG47L-20180202.zip
This has the following fixes:
- Fixed OTA update script to accept a ro.product.board of "q201" or "q20x".
- New build of Mali driver that supports OpenGL 3.2 + AEP
- New Bluetooth libraries that seem to fix the audio stuttering problem on the Longsys LTM8830.
I'm still seeing intermittent wireless issues, but I think we're getting pretty close. Anyone spot any other problems?
Originally posted by Magendanz View PostHere's another revision of our little experiment building Nexus TVStock for the M8S PRO on the Shiningworth All-in-One firmware:
It was a bugger, learning a few broadcom settings that I still have a vague understanding on, but made my weak tablet boost speeds up to 20% on weak 5Ghz signals. My google created drop offs are less prone, and yet to notice them for now.
Many thanks Magendanz, it works perfectly as expected for me !!!
Finally the problem with bluetooth audio transmission was run! This means the following:
My M8S Pro has a Wi-Fi LTM8830 chip, as you mentioned earlier that the chip on my device could be different.
What I find very cool in this firmware:
• Access to Status Bar and Notifications ✓
• Access to Power Menu in the Leanback Launcher ✓
• Possibility of Deep Sleep or something similar ✓
• Many other features that I still do not know how to use. ✓
Suggestions for the next updates:
• Keep the YouTube app running in the background without being completely closed:
- Whenever minimized the app closes completely, but previously in last year's build for Vorke Z6 it was possible to minimize and continue playing in the Leanback Launcher. It was also possible to access the recent apps and back to the point where it was previously.
• Correction in the sound options to avoid disconnection in the Bluetooth transmission:
- In Sound Options> How the sound echoes> HDMI Mode; In this option when the volume is reduced to the maximum the bluetooth app disconnects and it becomes impossible to maintain the connection until the device is the sound box to be restarted.
• Add the AirScreen app as default for ChromeCast or Miracast screen mirroring:
- Although we do not know the reason, the Google ScreenCast app does not work, so it would be interesting to remove this app and put the AirScreen app as the default as it does in the OEM firmware of Vorke Z6.
I think that's it, I'm very excited about this update, so I'm sorry if my suggestions are inappropriate
The M8S Pro with the 'bonus' Wideline L1 still lose that 'bonus'?
On the YouTube background behavior, was that by any chance the old version that wasn't based on WebView?
They completely rewrote YouTube for Android TV, and it's lacking some of the old features. More info here: http://www.androidpolice.com/2017/08...rand-accounts/
There are currently 3038 users online. 1 members and 3037 guests.
