[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
Originally posted by n3v3rm1nd View Post
i make this M8S_PRO-V0928_Nano-20171116.img file on sd card stop m8s pro put the sd card on slot push the reset buton and plugin power after 5 6 seconds robot android show for 1 seconds and screen is black and now my box is DEAD
Originally posted by surya77Dear magendaz, can you please provide onedrive link to your 20171109.180937.V0928 firmware? Cause i couldn't download from your freaktab link. Thank you.
FYI, I've decided to downgrade from your February released ROM, cause it made my box froze randomly.
Mine works without any problems with his February released rom - in fact it's the best one among all for M8S Pro, I only wish it had L1 support...
how can i revert back to stock? I downloaded the image MECOOL M8S PRO SD 20170817.zip but when i try to flash it via TWRP i get an error: "this package is for "M8SPRO" devices l this is a "q201_N"" i saw one post that talked about reinstalling twrp to fix this but where do i get that image from? the m8s pro isnt listed in their devices list.
You need to use one of the OEM OTA updates with the fixed update script like this: http://freaktab.org/5d1306cce48f4c3b
Originally posted by oweng View PostYou need to use one of the OEM OTA updates with the fixed update script like this: http://freaktab.org/5d1306cce48f4c3b.
trying to flash that and i get a new error
file_getprop: failed to stat "/system/build.prop": No such file or directory
Dear magendaz, just here to confirm that your feb released Rom turns out to be the best Rom I've ever used. I just realized what made my box frozed, it's my fault. I installed your feb ROM to my box without wiping it first. How stupid of me.
Thanks a lot for your hard work, really can't wait for more updates.
Originally posted by miki87 View Postfeb ROM
There are currently 1804 users online. 0 members and 1804 guests.
