Sent from my Nexus 5 using Tapatalk
[ROM] Mecool M8S Pro TVStock Nexus ROM (Android TV 7.1)
I have an issue with MECOOL M8S Pro (see spec below) while playing IPTV. Blank screen on specified channel with Audio ON.
While IPTV worked perfectly on much lower end MXQ Pro (see spec below)
No improvement even after local update to NEXUS M8S Pro.
Wrote to the IPTV service provider, it is suspected due to unsupported decorder format on the TVBox.
Below is the comparison on the support format on M8S Pro & MXQ Pro.
Decorder format for M8S Pro ($60+)
Decoder format for MXQ Pro ($30+)
Query,
1. Apart from waiting on for future firmware update hoping on to release more comprehensive support Decoder format.
Can someone recommend decorder installer procedure onto M8S Pro?
2. To my surprise, I found M8S Pro L (see below) actually do have more support Decorder format.
I tried with the local firmware update M8S Pro L onto M8S Pro. Resulted in error and could not complete due to Version Q20x
Decoder format for M8S Pro L
Thank you for your attention!
Guest
Changelog (20170930):- Updated to latest M8S Pro L OEM firmware (20170918.111557.V0619)
- Reverted to stock OEM recovery, due to new Android Verified Boot checks
- Underlying OEM firmware fixed the Action Bar bug in Android TV
- Underlying OEM firmware fixed the More Settings crash in Android TV
- Underlying OEM firmware updated to Android TV 7.1.2r11 (NHG47L)
- The Terminal app now shows only when enabled in Developer Options
- Restored default settings (e.g. animation scale, sound effects) from Nexus Player
- Latest build from Open GApps (20170930)
- TVStock Variant: BURN PACKAGE (978MB IMG file), OTA UPDATE (517MB ZIP file)
- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Originally posted by Magendanz View PostChangelog (20170930):- Updated to latest M8S Pro L OEM firmware (20170918.111557.V0619)
I see that Pro L is slightly more expensive than the Pro, which is weird since Pro has DDR4.
Am I missing something?Last edited by Guest; 05 October 2017, 07:45.
Guest
Changelog (20171001):- Rebuilt TWRP with new V0619 kernel, which seems to work on this device
- Bluetooth now starts on by default
- Added support for all HID devices (e.g. remotes, gamepads, etc.) on latest Nougat firmware for Nexus Player, NVIDIA Shield TV & Xiamoi Mi Box
Guest
Originally posted by Magendanz View PostChangelog (20171001):- Rebuilt TWRP with new V0619 kernel, which seems to work on this device
Thank you very much for your efforts!
I'm on M8S_PRO-V0619_TVStock-20170928. Can I OTA UPDATE over it?
Thanks again,
Best regards,
Edit: Yes, we can!!Last edited by Passaralho; 03 October 2017, 21:17.
Guest
Yes, that was because you previously had installed the non-ATV versions designed for tablets and phones. This custom ROM (and the V0619 firmware upon which it's based) is Android TV, and so has the Google Play Store for Android TV. I'm not familiar with RaiPlay, but Netflix for Android TV will refuse to play on devices that don't have Widevine L1 certification. You can still sideload the non-ATV version of Netflix by just installing it from APKMirror.com, but the Google Play Store for Android TV will only serve up Android TV apps.
Any one who has installed the latest firmware (20170918.111557.V0619) and has a Dolby Vision TV, can you check whether Dolby Vision HDR works? There are two options for Dolby Vision in this firmware (follow sink, follow source). I tried it with a LG OLED and it didn't work for me. You can find Dolby Vision clips in Kodi Wiki samples (http://kodi.wiki/view/Samples).
Guest
Just FYI, I did another rolling update this evening to address the following minor issues:- Set boot animation speed back to standard (not sure why VS messed with that)
- Set Android version number to correctly match the build ID (NHG47L => 7.1.2)
- Fixed preinstall script to stop overriding the 12/24 hr clock setting
Originally posted by Magendanz View PostJust FYI, I did another rolling update this evening to address the following minor issues:- Set boot animation speed back to standard (not sure why VS messed with that)
UPDATE: Had to reboot the device 3 times but it all seems to be working now. Really appreciate the work you have done on this rom.Last edited by boxno1; 09 October 2017, 11:09.
Originally posted by dani1215 View PostHow do you update the rom from 20170825 to the new one you released.
b) boot into recovery by pressing the reset button while powering on your box
c) flash the update like you would in an android phone
I think this is it!
Hi, to all
First of all, thank you Magendanz for your work building these roms!
I`ve tried 20171001 Nexus TV Stock rom and faced number of issues:
1. Wifi speed performance on 5Ghz seemed slightly slower then on VS stock V0321 firmware
2. Screensaver shuts down running apps, for example if i leave paused video on youtube or on Kodi player for 5min (default setting value for screensaver) ir turns off everything.
3.Facing green artifacts when playing videos (youtube, kodi). It appears for a few seconds when video play is started, then disappears. Sometimes appears in the middle of video playing, but its rare.
Previously used VS stock firmwares, also faced some instability issues. but none of these.
There are currently 1852 users online. 0 members and 1852 guests.
