Download Link
Updated kernels Download Link - These will up your speed quite a bit and ideally fix the OTG issue. Also bluetooth works now - testing needed though. There are two kernels in this download. One is at 100% screen scaling, and one at 95% for those people with issues and funky tv's.
Edit again: 8/15/13 my new batch of kernels made with new (to me) sources that will work on version 1.0 sticks for sure, not sure about v3.0. These are solid as hell on my mk908, and I offer 3 choices in each resolution. Fast, Cool, and Cooler. Fast is 1.7ghz cpu, 800mhz ram, ondemand scheduler default, adjusted voltages for stability. Cool is the same deal with interactive scheduler basically which helps some with the heat and sort-of caps the processor at 1.2ghz. Cooler has the processor turned down as well as gpu speed. Ram is still at 800mhz. This one runs really cool on my stick, even under load. Of course there's some heat but it's the best I've achieved. Anyway, here is the Download Link for mk908-jjhkernel-v3.3.
Enjoy!
