Those kernel sources had some things in them that appear to keep it at that higher rate.. I'm making some right now that should be better on the heat.
UPDATED - MK908 Finless 4.1.1 v1.4 - Repack with Vsync fix+
Originally posted by peteus View Post
Those kernel sources had some things in them that appear to keep it at that higher rate.. I'm making some right now that should be better on the heat.If my work benefits you and you want to help out the cause, feel free to
http://www.hoaby.com/android/donate.gif
Cooler temperature kernels
Added a link to cooler running kernels in the first post. Hopefully will help out people having heat issues.If my work benefits you and you want to help out the cause, feel free to
Originally posted by hoabycsr View PostThere are options in the kernel for that, but the weird thing is that this kernel is the same one I use on the 4.2.2 roms and the rotation is locked. I could try turning them on and seeing how it works on 4.1.1.. I know antutu rotates for sure so it'd be an easy thing to test. I'll see what I can do but it won't be until tonight. Got family things going on today.
Originally posted by hyperlogos View PostTried the new 'cool' kernel, I don't know how much cooler it is but I did notice that I can get 5MB/sec on my USB ethernet adapter, that's pretty good!
Which XBMC build do you favor? Alpha6 is tolerable...If my work benefits you and you want to help out the cause, feel free to
Best ROM so far
Hi hoabycsr, imho this is the best and most stable rom so far. I used the rom from the OP in this thread and the 411kernel100.img kernel.
- Wireless keyboard works again
- Bluetooth works
- Wifi works very good; wireless router is 2 walls away and I still get 24Mbit down and 14mbit up (internet); internal is ofcourse much faster
- OTG port works fine
- Can't give AnTuTu benchmark results; when opening the app it crashes/reboots
- ALL online streaming apps show video's without stuttering
- 720p and 1080p movies play fine, without any stuttering or hickups, from internal network (over wifi)
- Skype recognizes my webcam, but webcam doesn't show any video (Logitech USB webcam)
I'm happy with it. Only thing I don't understand: why does AnTuTu crash
Originally posted by cyclofosfamide View PostHi hoabycsr, imho this is the best and most stable rom so far. I used the rom from the OP in this thread and the 411kernel100.img kernel.
- Bluetooth works
The antutu crashes I have noticed are usually from too much heat or else not enough cpu voltage. Later this afternoon I will throw up my new kernels - one geared for speed and one geared for low heat. They should work well with this rom. I did some voltage tweaking and seemed to gain a ton of stability. I wasn't having the reboots with that kernel on my stick but I don't think these are all made the same.If my work benefits you and you want to help out the cause, feel free to
Must be voltage.....
Originally posted by hoabycsr View PostThe antutu crashes I have noticed are usually from too much heat or else not enough cpu voltage....
Originally posted by cyclofosfamide View PostMust be voltage then; after just cold booting the stick and executing AnTuTu it cannot rise it's temperature till skyhigh values so that there will be spontaneous reboots.
My thoughts too in this case.If my work benefits you and you want to help out the cause, feel free to
New kernels
I added some new kernels to the first post. version 3.3 jjhkernel.If my work benefits you and you want to help out the cause, feel free to
Originally posted by hoabycsr View PostI added some new kernels to the first post. version 3.3 jjhkernel.
Originally posted by hilltopper06 View Postversion 3.3 breaks my HDMI sync. It comes and goes every few seconds and artifacts when it is in. This is the first custom rom/kernel to do this. the stock rom mine shipped with suffered from this as well.
Thank you for the info, I will look into it tonight. V3 stick?If my work benefits you and you want to help out the cause, feel free to
There are currently 2437 users online. 0 members and 2437 guests.
