[ROM] Beelink GT1 / Alfawise S92 Stock & Nano Nexus ROMs (Android 7.1)
Do you have an archive of your previous releases? For me the 20171108 or even the 20170825 ROM where just so much smoother. No problems at all, my Air Remote understood simple things like powering on but more important, no freezes or lags with Kodi. I unfortunately deleted them and could pull off my hairs...
#301.1Guest commented03 May 2018, 08:17Editing a commentArchives are posted here: http://freaktab.org/folder/4/q201
Originally posted by jamespmi View PostDo you have an archive of your previous releases? For me the 20171108 or even the 20170825 ROM where just so much smoother. No problems at all, my Air Remote understood simple things like powering on but more important, no freezes or lags with Kodi. I unfortunately deleted them and could pull off my hairs...
https://mega.nz/#F!MmYnyZhI!1s6uM31zhcr1eugoCAH0kA and nexus nano & stock 19.11.2017 -
Originally posted by Djuganight View Postdoes this rom work with the GT1 Ultimate version A706DSCH ?
I have a 2/16 running GT1 OTA-SCV11-GT1.zip and all is good. I needed another one.
I bought a GT1 Ultimate
I flashed SCV1-GT1_Ultimate... bricked.
I flashed GT1_313M0_AP6255... bricked.
Now runnig Nexus_GT1_Nano_NHG47L-20180119.img and like it but FREEZE.
Afraid of BRICKS
Thank you all
Originally posted by Buldozer31 View PostAll that was found especially for you bro. Nexus nano & stock 25.08.2017 -
https://mega.nz/#F!4q5XkJaZ!T7WQ5_FONlEmA2YuzZNi3w
hello everyone! on the Vorke Z6 support page I have found the new ROM from 26.01.2018 with some good changes:
Change log:
1. Improve WIFI throughput, optimize network speed.
2. Repair blurred image when booting.
3. Unlock Vorke launcher (User Choice can be in the Set -> HOME options select android native launcher to start).
4. Add ROOT switch to Set (set to be restarted to take effect).
5. Add video playback frame rate adaptive switch to Set, off by default.
6. Update Chrome browser to solve the situation which the old version of some websites can not pop up the soft keyboard.
7. Add ariscreen apk, support airplay IOS 11 version, chromecast and so on. 8. Remove the speed test app and update the KODI software version to 17.6.Last edited by lexar4ik; 18 April 2018, 11:51.
Originally posted by PalkiZulu View PostHi there.
Could someone please tell me how to get cursor to move in TWRP Recovery. I am using Rii Bluetooth keyboard and standard remote to navigate but in recovery none of them are working.
Originally posted by Onassis View PostWOW !
This rom (v20171125) is the best !!!
In my experience, among all the others customized roms, this one produces the most crisp & vivid colors, specially deeper blacks (probably it's the only one that truly implements full-range or deep-color mode).
Guest you are really talented !!!
Hello everyone,
does anyone know what to do when you can't get past the android setup screen? I installed the nexus stock rom via SD card, it boots up but as soon as i want to get past the 2nd android setup screen, it just goes back to the first page of the setup screen where you have to choose the language etc.
Is it because I installed it with SD card, I cant use USB burning tool, that program always get stuck at 2%
regards
regards
I had the same problem when I flashed this to my gt1 ultimate, latest edition sn: b706db, it kept restarting the setup wizard. I guessed because of no network. But it also happened with cable. So my guess is he cannot show the wifi setup because the chip is not compatible. Km6335 i think. I hoped it would work bacause on page 1 it said many other driverd also included :-)
I now us the alvatech rom for the newer boxes on the ultimate forums without problems. But I'm also plagued by the fake ram :-(
Best regards,
Wouter
There are currently 2973 users online. 1 members and 2972 guests.
