[ROM] Beelink GT1 / Alfawise S92 Stock & Nano Nexus ROMs (Android 7.1)
Originally posted by jingo420 View PostI'm running Nano version of this rom on 706D0 GT1 Ultimate and it shows only 2gb or ram instead of 3gb. Any fix for this?
Originally posted by lexar4ik View Post
this rom is not for this version of box...for 706**** boxes at the moment is only official rom - http://www.bee-link.com/Beelink-27615-1-1.html
Originally posted by yehero View PostKris....don't forget my boxes! Okay?
Suddenly i have alot of Program has stopped working and with some of them i cant evit click wait or end if i try nothing happens .
i dont know what i have done , but could it be that i updates Superuser or something?
Explorer crashes almost everytime, Kodi crashes often to..
Maby i should do a reinstall ??
It's all good brother... You're doing enough already....
Your unique support needs to be sourced from the seller's customer support blog.
Find that at the main forum index.
your migh try?...
- Dump the dalvic cache.
- Reload the OEM rom
- Factory resetKris....don't forget my boxes! Okay?
Originally posted by ClarkKent View Post
Sorry friend..
your migh try?...
- Factory reset
Originally posted by FunThomas View Postis there a way to reboot to recovery without pressing the button in the hole ?
or is it possible to add a option in the power menu (when pressing power on/off button on remote) for reboot to recovery ?
or does someone know the commandline in terminal ?
thx in advance
There are currently 4173 users online. 0 members and 4173 guests.
