Hello I made the purchase of the beelink GT1, Waiting for reception
[ROM] Beelink GT1 / Alfawise S92 Stock & Nano Nexus ROMs (Android 7.1)
good afternoon friend Magendanz, I wanted to ask you a question? there has been some progress for the rom Beelink GT1 I have installed this rom in my tv box ms8 pro of 3gb of ram and 32gb of room already worked well but I have the problems mentioned in point # 52 and wanted to know if there is progress in the subject . Thank
Guest
Well, we don't have a release build of the T8X Max OEM firmware yet, only the beta release. A few days ago, however, I posted an updated M8S Pro TVStock ROM based on their V0619 firmware that VideoStrong just released for M8S Pro L. If you want more details on that, you should ask on that forum topic.
Good afternoon. I made the installation in two beelink GT1 ultimate box with wireless chipset AMPAK AP6255 and QCA9377. One with Nano and another with stock. Excellent performance. A lot of difference by the positive compared to the original ROMs. Thanks for the great work.Last edited by jomagaar; 03 October 2017, 16:23.
Originally posted by tht View Post
It seems that in build.prop if you uncomment this line and reboot the sdcard will be available to all Apps
#persist.fw.force_adoptable=true
I did it and ES Explorer can now find my sdcard and whatever data is there it should work with other apps I am sure.
Thanks in advance
Edit: fixed it though some googling
Magendanz
Great Rom but anyway I can remove Google Chrome as I need to reinstall an earlier version, otherwise I am not able to drag scrollbar with air mouse.
There are currently 1686 users online. 0 members and 1686 guests.
