[ROM] Beelink GT1 / Alfawise S92 Stock & Nano Nexus ROMs (Android 7.1)
hey. how to activate root? flash in twrp? installed supersu from play store and message say "su binary occupied". Thanks.
The underlying OEM firmware is already rooted, so you can type "su" in Terminal and it just works. If you want the SuperSU gatekeeping prompts, you'll have to figure a way to replace the su binary that's already there. (For example, you could delete it and try SuperSU binary update again, but I haven't tried that yet.)
Thanks. I did as i would my phone and flashed latest supersu in twrp. . Few things ive noticed, system sees the micro usb card inserted and with system explorer i can access files but using root explorer or solid explorer it see but wont connect. Checked all permission, etc. Lots of stuttering when using airmouse. Can't use remoteIME app to control device.
QUOTE=Magendanz;n666004]New build today, based on a new foundation. Let me know what you think!
Known Bugs:Bluetooth audio performance is awful on my Sony headphones. This needs to be fixed in underlying OEM firmware
First of all thank you for grate rom. Finally I have found good A7 rom for GT1 Ultimate.
Then about Bluetooth audio:
I replaced the following files (without lib64) with corresponding permissions and rebooted, then it works nice. BT.zip
Originally posted by jfive74 View PostThanks. I did as i would my phone and flashed latest supersu in twrp. . Few things ive noticed, system sees the micro usb card inserted and with system explorer i can access files but using root explorer or solid explorer it see but wont connect. Checked all permission, etc. Lots of stuttering when using airmouse. Can't use remoteIME app to control device.
Originally posted by manvel View Post
For me also: I can see SD card in total commander and copy files, but cannot see in ES file explorer? Strange and air mouse sometimes stop for a second.
I have GT1 Ultimate and it works perfectly but I have the same problem that some users with my SD card (Sandisk 64Gb).
I can see my SD card in the settings,
if I format it as removable storage I can see it and access to the files via the icon 'download' but I can't see it with ES file explorer, Mi Explorer or Kodi.
if I format it as device storage and define it as defaut, I can see it it and access to the files via ES file explorer, Mi Explorer or Kodi but I lose my internal memory !
I tested this rom Android 7.1 and TV Android 7.1 and it is the same problem.
I tested with the stock rom (7.1.2) and my SD card works correctly so it is not a problem of SD card. With the stock rom, I can access to my internal memory and my SD card.
Can you help me to revolve my problem, I would like to access to my internal memory (32Gb) and my SD card (64Gb) ?
taoktc
Guest
So, there were some changes to the platform.xml file on Nougat, but these are shared by OEM firmware (GT1_704N0) and the new ROM based on the T8X Max.
This segment has been removed:
Code:<permission name="android.permission.READ_EXTERNAL_STORAGE" > <group gid="sdcard_r" /> <group gid="sdcard_rw" /> <group gid="media_rw" /> </permission> <permission name="android.permission.WRITE_EXTERNAL_STORAGE" > <group gid="sdcard_r" /> <group gid="sdcard_rw" /> <group gid="media_rw" /> </permission> <permission name="android.permission.ACCESS_ALL_EXTERNAL_STORAGE" > <group gid="sdcard_r" /> <group gid="sdcard_rw" /> <group gid="media_rw" /> <group gid="sdcard_all" /> </permission>
Code:<!-- These are permissions that were mapped to gids but we need to keep them here until an upgrade from L to the current version is to be supported. These permissions are built-in and in L were not stored in packages.xml as a result if they are not defined here while parsing packages.xml we would ignore these permissions being granted to apps and not propagate the granted state. From N we are storing the built-in permissions in packages.xml as the saved storage is negligible (one tag with the permission) compared to the fragility as one can remove a built-in permission which no longer needs to be mapped to gids and break grant propagation. --> <permission name="android.permission.READ_EXTERNAL_STORAGE" /> <permission name="android.permission.WRITE_EXTERNAL_STORAGE" />
Originally posted by Magendanz View PostSo, there were some changes to the platform.xml file on Nougat, but these are shared by OEM firmware (GT1_704N0) and the new ROM based on the T8X Max.
I hope we are going to succeed to solve this problem because your rom will perfect for me ;-)Last edited by TAOKTC; 05 September 2017, 09:24.
Guest
Note that formatting as internal storage has always had some drawbacks, including losing access to internal /sdcard on the eMMC (which is usually much faster than SD storage).
There really should be no difference in behavior between Stock/Nano variants and the underlying OEM firmware (GT1_704N0 or TX8 Max), since the feature permissions (/system/etc/permissions) are unchanged. There are some significant changes for the TVStock variant for Android TV, but not for external storage.
The only thing that makes any sense is the change in behavior from Marshmallow to Nougat because of the changes to platform.xml above.
Originally posted by Magendanz View PostNote that formatting as internal storage has always had some drawbacks, including losing access to internal /sdcard on the eMMC (which is usually much faster than SD storage).
Originally posted by TAOKTC View Post
Thanks Magendanz for your great rom ;-)
taoktc
Further smoothest till now.
Originally posted by wakko45 View PostHi, is there a way to unroot this firmware? I'm looking to replace the stock on my Beelink GT1 (G912, DDR3), but I need an unrooted version because of my TV app.
system/lib/libsupol.so
system/bin/.ext
system/xbin/daemonsu
system/xbin/su
system/xbin/supolicy
Here UnrootGT1.zip is a zip I put together to do the above if don't want to manually do it. flash in recovery.
Attached FilesLast edited by tillaz87; 08 October 2017, 05:08.
There are currently 33946 users online. 1 members and 33945 guests.
