I'd rather not add any more clutter here, for my friends.
[ROM] Beelink GT1 / Alfawise S92 Stock & Nano Nexus ROMs (Android 7.1)
Originally posted by [email protected] View Post
What do you mean by same issue? You also had problems downloading the ROMs?
PS: Link to ROMs is online again
i never had any issue with the download of the file
philippe
Originally posted by [email protected] View PostHow do I boot into recovery? I tried using some apps from playstore to perform a reboot into recovery but they don't seem to work. I have installed the 251117 (latest nano version)
Thanks!!!
Otherwise, unplug power use a paperclip to gently depress reset button inside v. small port hole on base panel.
You'll hear and feel a click, apply power hold depressed for ? a "5" count. Should do it.
It's tricky to stay on button and may be easier to poise wall plug just off making connection. Use two hands on box, then seat wallplug with ? elbow, etc.Kris....don't forget my boxes! Okay?
Originally posted by ClarkKent View Post
Reboot v.2.1 or rom toolbox ( j.Rummy apps) works well for me. Try those and see?
You can also download “amlogic tv box tool”. It will give several tweaks as for exemple the possibility to reboot in Recovery mode ..... that’ s it !
Guest
I received my new GT1 Ultimate from GearBest in the mail yesterday, and I've now tested it with this latest ROM. Unfortunately, I found a 1-byte error in the device tree for the 3GB DRAM configuration that will cause a hang after the boot logo. I've corrected the mistake and have done an in-place refresh of all the links from the last build, so now everyone should be downloading new copies with the fix.
This rolling update is only for the 3GB DRAM GT1 Ultimate configuration. All others should be unaffected.
Originally posted by Magendanz View PostI received my new GT1 Ultimate from GearBest in the mail yesterday, and I've now tested it with this latest ROM. Unfortunately, I found a 1-byte error in the device tree for the 3GB DRAM configuration that will cause a hang after the boot logo. I've corrected the mistake and have done an in-place refresh of all the links from the last build, so now everyone should be downloading new copies with the fix.
it seems that there is not any new release.
silent release ?
philippe
I have your August Nano build, that's all that would flash at the time. Other than a factory wipe is there anything else needed to move up to your most recent version?Kris....don't forget my boxes! Okay?
Just tested this rom today and this is what i've found
- On every boot, bluetooth enables itself
- Some apps say that internet is not available when connected with ethernet. Example: tunein radio
- Auto-switch to best resolution not working on kodi
- Missing passtrough options (dts, dolby) on kodi unless you mess with some sound options on android settings
- Mouse cursor is too small @ 4k resolution
The good: - Rom is super smooth. No crashes
- Correct brightness
- No bloatware installed. Perfect!
Apart from those minor issues, I'll keep using this rom. Hope to see an update soon!
Guest
On the Bluetooth auto-enable, I set that default so that people can auto-detect Bluetooth remotes on initial setup. It's also the default on the Nexus Player.
The only negative think I noticed is that ethernet connection goes away after waking the device from sleep.
so I have to reboot the GT1 everytime I use it.
a workaround could be to turn the box completly off after pushing the red button once on the remote.
thanks dev for the rom!
Been using it for 2 weeks now and it works wonderful only problem was that i couldnt turn off my reciver when i hade CEC enabled so i turned it of.
Otherwise everything is running smooth execepts for some Kodi crashes but i blame that on the Kodi team or because i have alla movie/tv info on SQL server on my windows 16 server.
Keep up the good work.
There are currently 4029 users online. 0 members and 4029 guests.
