[ROM] Beelink GT1 / Alfawise S92 Stock & Nano Nexus ROMs (Android 7.1)
Thank you very much for the ROM! It's great. However, I am experiencing some intense freezes of the cursor when using an air mouse. Any idea why? Thanks!
#91.1Guest commented12 November 2017, 03:38Editing a commentI've noticed the same with my USB mouse, which I mentioned in the Known Issues section of the release notes. This should be fixed in the next release (which I didn't quite finish before heading to Boston for the weekend).
If you want to try a prerelease build, though, it's available here: https://1drv.ms/u/s!AoqocX31ecnXgadRBGApyrTx2NuCswLast edited by Guest; 12 November 2017, 04:00.
Sorry, I mesnt to post this on the 7.1 TV thread, but all the same.
that location was correct. Once I entered it into Magisk, I was able to update from 14.0 wothout issue. I noted the issue and the correct boot image location in their beta thread on XDA. Hopefully the issue can be resolved going forward. Otherwise it moght be good info for the OP. Magisk works well and had a module (Universal Safetynet fix) that causes safetynet to work on just about anything regardless of root.
Hi Magendanz
I have downloaded the last nexus 20171110 img file inside my gt1 ultimate AX12. It works fine except:
impossible to affect the function of stop remote .
I have a remote control with microphone . It worked with the superceleron image but it does not work with yours. When I press the microphone, it opens the upper task bar
Any solution ?
thank you
regards
philippeLast edited by Philbra; 14 November 2017, 14:46.
Magendanz, any idea when the latest shinningworth all in one related firmware will be releases?
thanks
Well, I just got back late last night and am working on an update for M8S Pro L today. The GT1 update based on the 20171101 SW AiO firmware will probably be later this week. (I have to resolve the Bluetooth audio problem, confirm the ActionBar fix, tweak the TvSettings.apk, and find the setting for the auto-hide status bar feature.)
Guest
Changelog (20171119):- Now back to the latest Shiningworth All-in-One firmware (Vorke_Z6-20171110). No more hybrid with VideoStrong framework.
- Added local update and backup option from Settings->About->System update based on Amlogic stock OTAUpgrade app.
- Back to the previous set of OEM-specific options available in Settings, particularly with Display and Dolby/DTS features in Sound.
- The navigation bar can now be shown or hidden via the setting in Settings->Display->Toggle Navigation Bar.
- This underlying OEM firmware is not rooted. You can install SuperSu or Magisk, if you need this.
- Latest build from Open GApps (20171119)
- I'm still seeing some stuttering with Bluetooth audio.
- I need to make some adjustments to the device tree to get S/PDIF audio working.
- Clicking on Vision Settings in the setup wizard will launch an unsupported activity in Settings.
- If holding reset button to boot to recovery, release after 10 seconds and then wait for almost a minute. It will eventually get there.
- Nano Variant: BURN PACKAGE (1.02GB), OTA UPDATE (515MB ZIP file)
- Stock Variant: BURN PACKAGE (1.52GB), OTA UPDATE (833MB ZIP file)
There are currently 2673 users online. 0 members and 2673 guests.
