thanks
[ROM] Beelink GT1 / Alfawise S92 Stock & Nano Nexus ROMs (Android 7.1)
Originally posted by ChJ View PostMe again.
As Nicoxygen already mentioned in July (post #6) AZERTY layout kbd (for French) is not included in the setup...
And this is absolutely not in line with my wife acceptance factor !
Do you have an idea when it could be ? (If I may help, would be my pleasure)
Magendanz commented: Can you point me to a .kl file for that? I have all of them from the Nexus Player, NVIDIA Shield TV and Xiaomi Mi Box, so I've exhausted those repositories.
The .kl file for the kbd Rii Mini i8+ Wireless (AZERTY) is Vendor_1997_Product_2433.kl, already included in your ROM. Of course, this file maps the QWERTY version.
As there is no Vendor_1997_Product_2433.kcm file in /system/usr/keychars directory I created one to map the Key Code names given by the .kl to characters in line with the AZERTY version of this kbd.
I thought I could have a trial on my box, but couldn't because my ROM is not rooted. After a quick search, didn't find how to root it... will have to dig more, but if any advice..?
I join the .kcm in zip (upload refused with .kcm extension ?) if you want to test it...
Thx
OK, let me try with TWRP. And I come back on you soon with improvements, certainly. I already found some...Attached FilesLast edited by ChJ; 22 December 2017, 10:04.
Some apps are not available in playstore like mc browser and and an Arabic tv app name DMI . I have beelink GT1 Ultimate , with the stock firmware all apps are shown
So, the Android TV variant (TVStock) has Google Play Store for Android TV and the non-ATV variants (Nano & Stock) like this have the "mobile" Google Play Store. By design, they only list apps designed to function on the target platform.
You can usually, however, load other apps from sites like APKMirror just by installing them from Chrome.
Originally posted by Rani2add View PostWell, but why are these apps available in plat store when using beelink stok rom ( from their website )? there should be a way to make them available in custom roms
and you will have a lot of application whatever the ROM is
phil
Thank you so much for your efforts Magendanz. Recently I installed Nano ROM on a beelink GT1 Ultimate. It is working smoothly except 3D games, apps like Google Earth still crashing. There are two things I would let you know. I'm not able to copy from Chrome (except address bar). When I power off the TV box first boot doesn't recognizer the main launcher (I installed Nova), after booting the second time it works fine.
Thank you.ÂÂ
With the latest version, I keep running into an issue where it seems like the settings arent sticking after reboot. I have to adjust by screen position to zoom out (91%). Now after every reboot, the screen is out of focus and I have to keep setting it. Also, Bluetooth keeps getting re-enabled after every reboot despite disabling it every time. This is occurring on two different boxes, including a brand new box that Im setting up.
Is there somewhere that we can download the previous versions from? It happened somewhere between the 1108 and latest version.Last edited by Gorilla P; 29 December 2017, 07:37.
Originally posted by Buldozer31 View PostHello. Will there be an assembly of Nexus on Android 8.1? I see no reason to update this assembly any more ..
as the outcome would most likely be partly broken, without amlogic / other vendor updates (wifi BT ect)
I just installed your rom on
Edal K12 Pro Android 6.0 Amlogic S912 2GB/16GB
(you should add it to the title so others can find it and do the same)
got it from amazon, everything works, but there are a few issues
my Rii mini i8+ is a bit off
I can't tell if it's slow or somehow skipping
what's happening is that sometimes if I am typing quickly, it will miss or repeat some letters
It never did this before with other operating systems on other systems (win 10, retropie, osmc, android 6 etc)
any ideas?
can't install android tv launcher (is this only for TVs? not android boxes?)
can't get "Android TV Remote Control" apk to work (should it?)
has anyone ever been able to get retroarch to work? how?
Now, I'm trying to get root and can't seem to get good instructions anywhere.
Kingroot and others didn't work.
I have found instructions to do this on xda for other devices in a post called:
"Mecool KM8 P 2GB/16GB S912 Amlogic TV Box Android 7.1, TWRP Root Instructions Russian"
Does anyone know a quick and easy way to do this?
one that maybe doesn't require flashing a non official twrp for another brand box etc...
Buy Edal K12 Pro Android 6.0 Amlogic S912 2GB/16GB Octa Core CPU TV BOX: Streaming Media Players - Amazon.com ✓ FREE DELIVERY possible on eligible purchasesLast edited by grendude; 30 December 2017, 23:36.
FYI - Installed root by placing
recovery-twrp-3.0.2-T95Z.img
on an sd card
FIRST: rename it to simply
recovery.img
booted holding the reset button
waited
twrp booted
from there installed supersu.............zip from the official website
removed sd card
booted
waited as it rebooted a few times
now I have root and successfully installed adblock
Running this rom (Nexus_GT1_Nano_NHG47L-20171125.IMG) on tz95plus 3GB / 32GB and its works VERY well. As indicated above a bit of skipping or multiple letters on Rii mini i8+. Rooted using magisk and running exposed framework for some minor tweaks. Audio is using viper for android and output via spdif. Box is stable and has been running for days at a time with no freeze ups. Also using TV Launcher 3 as primary launcher.
The only things not working that I am aware of are the LED control (on/off multiple colours) and the clock display as I assume these are not in the device tree for this ROM.
Very good work. Thank you.
Originally posted by ynot123 View PostRunning this rom (Nexus_GT1_Nano_NHG47L-20171125.IMG) on tz95plus 3GB / 32GB and its works VERY well. As indicated above a bit of skipping or multiple letters on Rii mini i8+. Rooted using magisk and running exposed framework for some minor tweaks. Audio is using viper for android and output via spdif. Box is stable and has been running for days at a time with no freeze ups. Also using TV Launcher 3 as primary launcher.
There are currently 3607 users online. 0 members and 3607 guests.
