[ROM] Beelink GT1 / Alfawise S92 Stock & Nano Nexus ROMs (Android 7.1)
Hi magendansk
last ROM in my AX25 version
no issue until now. I did not loose anything
just on minor issue: previous (November) ROM was rooted with Supersu. With the new Rom and option root activated ( per default) supersu applett says « SU binary occupied »
i assume it is not compatible and should be unsinstalled
good WE
Philippe
My GT 1 Standard SN A912BKC and GT 1 Ultimate SN A706DSB are running very good also with last update. Thanks. The Ultimate shows 2 giga in Kodi, should be 3 giga. But no probleem. Nice you can boot simple again in recovery with https://play.google.com/store/apps/d...s.tools.reboot. Looks like hdmi cec is also improved. When I restart the box, the television is not going off. With both boxes it is fixed, one with Panasonic tv and one with Sony TV.
Netflix stays hd, with root on or off, no difference. Maybe Netflix checking root only with installation.
When change video playback frame rate adaptive switch to 1 or 2, Kodi and Netflix get slower. so I don't use it.Last edited by BeeRom; 21 January 2018, 09:41.Beelink GT 1 Standard SN A912BKC / GT 1 Ultimate 3 gb ram SN A706DSB
Yes my device has S / N A706D serial number (AP6255).Although it is 3 gb ram, it shows 2 gb.Can you fix this?Thanks for everything, my friend.
Guest
add to Changelog (20180119):
- no 3D support, no AnTuTu 3D tests, no 3D games => same problem with stock version, maybe try another or wait to new build
proof tested with nano can see here: https://photos.app.goo.gl/D6O0CZKNv7rSsuqT2
same situation on same version for VORKE Z6
previous version Nexus_GT1_Nano_NHG47L-20171125.img works fineLast edited by mXHX; 21 January 2018, 23:35.
I just ran 3DMARK Slingshot successfully. (It wasn't very fast, but it ran.) I wonder if they changed something in the AnTuTu 3D plugin. (Let's face it, these devices aren't really known for their 3D gaming performance. It may have just failed to meet some minimum performance threshold.)Last edited by Guest; 22 January 2018, 00:25.
Originally posted by JoseM View Post
i reported those errors to vorke team but could you be mores specific about no 3D support ? no 3D games ?
It will be maybe just some build.prop or .rc file switch. Secondly they forgot implement LiveWallpapers in their nougat builds, which is also very missing. Vorke_Z6-20171221 and Vorke_Z6-20171110 too.
But if you are in contact with them, another performance issue is this: http://freaktab.com/filedata/fetch?photoid=703737 > H.264 multicast FullHD stream in native decoding after few minutes or hours on auto screen resolution (1080p60Hz). Mentioned before here: http://freaktab.com/forum/tv-player-...082#post704082
FEverything seems to work good so far on my s/n AX12 box. The only problem I'm having is my Bluetooth keyboard pairs fine, but does not function. It worked perfect on the original stock rom that came on the device.Last edited by skinzaholic; 24 January 2018, 05:54.
Thank you for this ROM. Best one so far for my GT1 - 1080p DTS / DD videos working on Krypton Kodi, SPMC and Media Players.
Just one request can you please make it possible to make add on your next release; the possibility to have an active wifi and lan connection simultaneously? Some apps require an active wifi connection to the network (it does not detect the LAN as an active connection). The specific app in question is "Samba Filesharing for Android"
There are currently 2924 users online. 2 members and 2922 guests.
