[ROM] Beelink GT1 / Alfawise S92 Stock & Nano Nexus ROMs (Android 7.1)
Guest
If anyone wants to try out a prerelease build of the GT1 Nano Nexus ROM based on the new GT1_705N0 for QCA9377 that was posted today, here's a link:
Nexus_GT1_705N0_Nano_NHG47L-20171101.img
Note that this borrows heavily from the VideoStrong V0619 release that fixed many bugs, especially for the Android TV variant (which is also forthcoming). It's also no longer using the ShiningWorth All-in-One ROM, so I will need to release an update for the AMPAK wireless chipsets.
buenos dÃas megendanz, tengo una pregunta en la versión preliminar de #77, se corrige los problemas conocido de la versión anterior que eran problema de conexión y Bluetooth
Guest
Changelog (20171108):- New system apps and framework from M8S Pro, but still built on the All-in-One TX8 Max kernel and foundation.
- Added additional option (Sleep) to global action menu that displays when you press and hold the Power button.
- Fixed Bluetooth audio stuttering problem. (Have confirmed on QCA9377 wireless chipset, but not AP6255.)
- Fixed issue with external storage not showing up in some applications.
- A new set of OEM-specific options are available in Settings, particularly with Display and Dolby/DTS features in Sound.
- Removed attempt to launch voice assist on Back button long press. (Only valid for watches)
- Added support for all HID devices (e.g. remotes, gamepads, etc.) on latest Nougat firmware for Nexus Player, NVIDIA Shield TV & Xiamoi Mi Box
- The navigation bar can now be shown or hidden via the setting in Settings->Display->Statusbar.
- The Terminal app now shows only after being enabled in Settings->Developer Options.
- Releasing as OTA updates (.zip file) as well as Amlogic burn packages (.img file)
- Latest build from Open GApps (20171108)
- Nano Variant: BURN PACKAGE (924MB), OTA UPDATE (475MB ZIP file)
- Stock Variant: BURN PACKAGE (1.44GB), OTA UPDATE (812MB ZIP file)
- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Has anyone tried this ROM with the Tanix TX9 Pro? I don't have one yet, but am considering buying one to use with this ROM. From what I gather, the TX9 Pro should have the following specs:- q201 board
- 3GB DDR3 RAM
- 32GB storage
- AP6255 or QCA9377 wireless
Would also appreciate any experience (success or fail) with the Vorke Z6 or Tanix TX92. Seems to be very similar to the TX9 Pro, but with DDR4 RAM.
Thanks.
thank you for this great rom, I am really enjoying it.
I found two problems on 20171108, bluetooth is not working on A912 version (doesn't turn on), so as wi-fi (it scans but cannot connect)
thank you for your hard work!
Hi Magendanz
Very good rom, all working but shut down button function as a reboot and restart, anyone else having the same issue?
Hi Guys,
i've just installed the nano version . i have an issue with Luncher. I'm not able to switch from google Now Luncher to an other one.
I've installed Nova Luncher and also Lighthome Luncher but It does not accept. How to do please?
thanks
There are currently 4647 users online. 0 members and 4647 guests.
