Tanix TX92 Amlogic S912 CPU Android 7.1 OS 2.4G / 5G WiFi 1000M LAN BT4.1
Hello all! I was wondering if I could get your input/help. I just bought the Tanix X92. Upon starting the box I automatically went to pair my Rii 8 Bluetooth mini keyboard. The pairing was successful however I have no functionality of the keyboard at all?? I thought it may be a firmware issue so I updated the firmware to the 12/30 version posted on this thread. What else can I do??
After updating the firmware to 20171230, the "TV Center" app disappeared (the box where it appeared previously says "null"). Impossible to download Kodi -- from Google Play it tries to install and then gives an error (there is no problem installing other apps), and installing the apk from the kodi.tv site gives the error "app not installed, the package conflicts with an existing package by the same name" -- but neither "TV Center" nor Kodi appear to be installed (checking in Google Play store list of installed apps, as well as in the Apps section of the main TV Box settings menu). Has anyone else had this problem and how can it be overcome to install Kodi? Perhaps there are files remaining somewhere in some Android system folders from the original TV Center install that have to be removed? If so, I'd appreciate any help anyone can provide in locating and deleting them (not very experienced with Android)... Thanks in advance!
Originally posted by brycewaters10 View PostAfter updating the firmware to 20171230, the "TV Center" app disappeared (the box where it appeared previously says "null"). Impossible to download Kodi -- from Google Play it tries to install and then gives an error (there is no problem installing other apps), and installing the apk from the kodi.tv site gives the error "app not installed, the package conflicts with an existing package by the same name" -- but neither "TV Center" nor Kodi appear to be installed (checking in Google Play store list of installed apps, as well as in the Apps section of the main TV Box settings menu). Has anyone else had this problem and how can it be overcome to install Kodi? Perhaps there are files remaining somewhere in some Android system folders from the original TV Center install that have to be removed? If so, I'd appreciate any help anyone can provide in locating and deleting them (not very experienced with Android)... Thanks in advance!
Have a look. Everything is working fine with Kodi.
Originally posted by RASTAVIPER View Post
I have discussed about this issue some posts earlier.
Thanks RASTAVIPER, but I don't seem to find the post where you discussed this (I searched through this thread and didn't find anything)... Could you please elaborate and/or let me know which post number to look at? I just don't manage to install Kodi no matter what I try... Thanks!
Check posts 277 onwards
Thanks, I found the posts. I see that you had the same problem after updating the firmware. You later posted "So everything looks good so far with latest update. Youtube plays at 1080p, Kodi 17.6 was installed fine through Play store finally and no other issues" -- but unless I missed it, you didn't say how you achieved this. Someone had suggested doing a factory reset and then updating the firmware while erasing data -- is this what you did to get Kodi to install?
In your case, have a search in root/system folder and check if there is any apk with similar name to the tv center. Then delete it.
Maybe it's interfering with the ability to install it from Play store
Sent from my ONEPLUS A3003 using Tapatalk
Originally posted by RASTAVIPER View PostNo, just as I have written, I managed to install KODI normally through Play store.
Originally posted by EyyyBooB00Hello all! I was wondering if I could get your input/help. I just bought the Tanix X92. Upon starting the box I automatically went to pair my Rii 8 Bluetooth mini keyboard. The pairing was successful however I have no functionality of the keyboard at all?? I thought it may be a firmware issue so I updated the firmware to the 12/30 version posted on this thread. What else can I do??
Sorry for all the questions and thanks for your patience, I'm quite new to Android... I did manage to do a search in all the root/system folders (using ES File Explorer), and found that in the system folder, there's a subfolder called xbmc_preinstall, which contains a zipped file (org.xbmc.kodi.zip) and an apk (TV-Center.apk). I don't know why they don't pre-install/load, but in any case, I tried deleting them -- but I got a message saying that they could not be deleted (I tried both the folder and the individual files). Do I need to do something in order to get "permission" to delete a system file (like the sudo command in unix)? Is there some other way of deleting these files? Since I couldn't delete them, I tried installing the TV-Center apk, but I ended up with the same error message as when I tried to install the kodi apk ("app not installed, the package conflicts with an existing package by the same name")... I then again tried (several times in a row) to install kodi from the Google Play store, but I just keep getting the error message every time... Any suggestions?
You need to delete these files. I remember also that installing them didn't help.
If u can't Delete them, then your root rights are not active.
Try a different file explorer or try to check why root rights inside ES explorer are not active.
Also, check in apkmirror and download the latest Kodi apk. Check if u can install it manually.
I am pretty sure that this is the problem.
There are currently 2182 users online. 0 members and 2182 guests.
