Okay guys, this is definitely something to do with authorisation for devices. I deauthorised all my devices and then reauthorised the ones I actually still have and it's back working. The only problem is that instead of going silent on the next song, it says 'the stream could not be played' but if I just click play again it plays the song perfectly.
Solve this Mystery!! Google Play Music goes silent
Solved... Kinda
Originally posted by griffdaddy View PostOkay guys, this is definitely something to do with authorisation for devices. I deauthorised all my devices and then reauthorised the ones I actually still have and it's back working. The only problem is that instead of going silent on the next song, it says 'the stream could not be played' but if I just click play again it plays the song perfectly.
Originally posted by griffdaddy View PostIt doesn't happen all the time and if does I just double tap enter on the keyboard. To be honest it's probably something we just have to wait for Google to fix, I'm sure they will. I already wrote to them about it.
Re: Solve this Mystery!! Google Play Music goes silent
Sent from my GT-I9505 using Tapatalk 2_________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
Originally posted by Niall View PostSo did anyone ever find a fix for this. One of the main reasons I bought my T-R 42 Android box was for Google Music, real pity it's not working.
Any ideas anyone?
using spotify and have cancelled my paid google music account too.
i too am curious to know if anyone/google sorts it out_________________________________________
Originally posted by Niall View PostGoogle Music's latest updates didn't solve it. I'm not using All Access I'm just streaming my uploaded music. Very strange,need one of the resident genius's to figure it out...
Guest
Any ideas anyone?
My box has the 2.0 board and is coonected by LAN.
Greetings
grezwolf
I have found a solution that is working for me on. I'm guessing that this should work on other RK3188 devices. It seems that Rockchip has implemented the use of ffmpegmediaplayer in their development image. For some reason, this media class causes the Android mediaserver (/system/bin/mediaserver) process to die when Google Play Music performs certain actions. I didn't dig deep enough to see what Google Play Music was doing to cause the error. I didn't have problems with other music apps, but they may not use Androids built in media player.
The solution is a simple build.prop edit. I believe this edit effectively disables ffmpegmediaplayer so keep in mind that you will lose the extra codec support / features that it provides. This was not a big deal for me. Some of this information is speculation / assumption so don't take it as gospel. If anyone out there is more knowledgeable than me on the subject please interject. I do know that Google Play Music now works for me without a hitch. Before it was crashing / throwing errors after reaching the end of the first song. The solution was to change (in build.prop) and then reboot:
sys.ffmpeg_sf.switch=0
to
sys.ffmpeg_sf.switch=1
Thank you
I just wanted to say thanks - this has been driving me crazy, I couldn't find anything else on the web.
I altered the build.prop and it now works like a charm
I have an Imito QX1.
Thanks again.
"The solution is a simple build.prop edit. I believe this edit effectively disables ffmpegmediaplayer so keep in mind that you will lose the extra codec support / features that it provides. This was not a big deal for me. Some of this information is speculation / assumption so don't take it as gospel. If anyone out there is more knowledgeable than me on the subject please interject. I do know that Google Play Music now works for me without a hitch. Before it was crashing / throwing errors after reaching the end of the first song. The solution was to change (in build.prop) and then reboot:
to
sys.ffmpeg_sf.switch=1 "
There are currently 1538 users online. 2 members and 1536 guests.
