So there's no way to edit that of course; has anyone found another alternative for this? Or is this something we have to wait on Google to fix?..
Solve this Mystery!! Google Play Music goes silent
Originally posted by Marque View PostHello guys; I'm new to this forum, but not new to "forums" per se'. I've been searching on this matter for close to a week now, & did find this thread earlier in the week, only to find out that KK 4.4.2 doesn't have that text in the build.prop.
Unfortunately I was never able to find out how to fix this problem with KitKat on my Rockchip devices. I had to stick with Jellybean ROMS. I don't know if this is something that Google needs to fix or will fix. Seems like a problem with how Rockchip uses a custom back end media processor.
But I was hoping the Telos would remedy the Google music problem. I'll gladly go to a Jellybean ROM if that's what it works with, because being able to play music (from Google music) is a biggie for me!..
Hi every left over of the CS918, K-R42 and other RK3188
I found a solution using the patch Wasser create for the Minix Neo X7. Thank you to him for all his work
You need root access for this.
patch (flash zip with the recovery mode):
wasser-google-play-music-silent.zip
source link forum:
minix-neo-x7-wasser-firmware-2-0-3-kitkat-android-4-4-2
This patch replace the file " libmediaplayerservice.so " file located in " system\lib "
For my part I did not flash the zip file, I have replaced libmediaplayerservice.so file manually
It worked for me on my CS918 wtih ROM Wasser Kitkat 4.4.2 v1.04.
Good luck
There are currently 1534 users online. 2 members and 1532 guests.
