Not the end of the world if stuck with this, yet though I'd try to restore android and run LE from USB stick only as the internal feature is being dropped.
If I press or press and hold the reset button underneath it just reboots the device then starts up normally. Just seems to do reset only.
I've downloaded the Amlogic USB firmware flashing tool and tried to connecting that to the OTG port and nothing detected... Oddly with this USB connected to my PC I can run the device without the DC power in jack connected!?! Its getting power from the USB...
Who knew?!
Something smells fishy about all this, yet last attempt is the card maker software and a MicroSD... If not looks like I have a LibreElec device only.
Anyone else had issues resetting these?
