Στάλθηκε από το MI 5 μου χρησιμοποιώντας Tapatalk
Firmware Stock: Android 7.1 Z69 Smart TV BOX S905X 3GB/32GB 802.11b/g/n LAN Bluetooth
Originally posted by jimennis View Post
arcanaXknight Hi , using amlogic customization to i copied from the stock rom the missing contents of folders etc/bluetooth and etc/firmware and from the system/lib/hw the bluetooth.default.so , plus the folder system/lib/rkbt and the rest of the content of the system/lib folder .These were then added to the working folder of the unpacked atv rom placed into their identical folders and repacked the image
Originally posted by jimennis View PostarcanaXknight Hi , using amlogic customization to i copied from the stock rom the missing contents of folders etc/bluetooth and etc/firmware and from the system/lib/hw the bluetooth.default.so , plus the folder system/lib/rkbt and the rest of the content of the system/lib folder .These were then added to the working folder of the unpacked atv rom placed into their identical folders and repacked the image
I didn't replace the existing file, just add the missing one, is it right ?
The ROM is build i will test it tomorrow.
Originally posted by arcanaXknight View Post
Thanks i will try, i made a few adjustment to an android tv 6 rom to use it on my z69 2g/16g but ethernet and bt didn't work, i will try your solution for bt from my stock android 6 rom.
I managed to port the magicsee N5 7.1.2rtl8723bs rom to this box by simply copying the boot and system partition of the magicsee rom to the stock rom using amlogic customization tool . Flashed with usb burn tool using force erase option and uncheck erase bootloader . link to magisee rom https://mega.nz/#!nGIWkayD!-FQ_4NScm...MoZH5tYArz8NiM .
I also installed and booted oreo using supercelerons Khadas.Vim-SCV1-WIP-Oreo_AndroidTV by replacing bootloader ,wifi doesn't work and ram limited to 2gb but does feel snappier .
There are currently 2572 users online. 0 members and 2572 guests.
