Στάλθηκε από το MI 5 μου χρησιμοποιώντας Tapatalk
Firmware Stock: Android 7.1 Z69 Smart TV BOX S905X 3GB/32GB 802.11b/g/n LAN Bluetooth
Originally posted by jimennis View PostI see that , I'd try leaving the dtb file thats on the atv rom the but don't transfer the amlsdc_burn file ,only bootloader and uboot usb file .I repackaged doing that but I don't have a 2g to test on
[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error!!
Why? Do you have any idea? I tried to flash it without erasing bootloader....later with erase bootloader on, but still nothing.
Do i have to root my current rom, or somehow unlock the bootloader before trying to flash anything?
Do i have to short some pins? (my device is being detected correctly without shorting pins)
Originally posted by jimennis View PostMake sure you use power supply also and force erase rather than normal erase ..good luck
Also, i think that it could not be flashed on the 2gb version, because the 2gb/16gb version, does not have a stock android 7 firmware. It has the old android 6, so it's not compatible!!
Originally posted by KF2018No. My box came with this version. That's why I've written about not knowing how to extract image from my box.
Originally posted by thegbThere are 2 versions of z69 2gb. One version has an elpida/micron emmc chip and the other one has a samsung chip. Do you know which one you have? You can find out, if you unscrew it. They have different roms. I have the Samsung version.
There are currently 2376 users online. 0 members and 2376 guests.
