I hoped that USB ethernet adapters will eventually work on some non stock firmware.
[ROM] AlfaWise H96 PRO Dongle 2Gb/8Gb - SCV1-ATV 7.1.2 ( ANDROIDTV VERSION )
Great Job; this ROM is far away better than the native one
No more wifi crash, freeze and other issues !!
The vocal research works fine everywhere, with Youtube too. My remote include a mic, I just have to push the mic button for that.
Indeed, I haven't the habit to don't use the mousse, but with the mousse the OK central button don't act like a clic, so I desactive the mousse mode, and all is ok
Except that I haven't the habit to navigate only with de rows ...
A little issue detected is a green screen on 360 video in Youtube ... If someone have some tips to share about it, it's probably just a stupid param or some missing codec ...
Bug again, thanks for this amazing work !
Because I've a local media server, I don't really need Kodi, just a simple dlna player, I don't know how to desinstall the unnecessary apps, but again, I'm a noob with the android tv roms
I flashed mine using one of the usb ports on the back of the dongle , load usb burner , select image then start - then plug the dongle in via a USB a - a cable ( I used an old one for an external ide caddy ) . Mine went green with good flash first time. Plugged in and no HDMI output , tried flash again and it failed , tried a third time and got 4 failed flashes , then 5th time worked ok and is now fine
superceleron many thanks for this rom - its exactly what i was looking for. Super quick and just works .... except for HDMI CEC. This does not seem to work even when enabled in settings. I have 2017 and and 2015 samsung tvs and neither work. Any ideas?
Originally posted by adamsdavis View Postsuperceleron many thanks for this rom - its exactly what i was looking for. Super quick and just works .... except for HDMI CEC. This does not seem to work even when enabled in settings. I have 2017 and and 2015 samsung tvs and neither work. Any ideas?
For now i can only recommend you guys use another type of remote, until i have the time to check it!
Thank you for this ROM. I really like the small form factor of this device and I want the android tv experience mainly for Netflix but I am having issues flashing this on my H96 Pro HDMI dongle.
i connect usb to one of the USB ports (not the one close to the micro usb side, the other one, but have tried that as well) then the other side of the male to male to my computer.
At that point the led of the dongle is lighting red.
Then I load the image using the usb burning tool and then press start. Then I connect the micro usb cable that powers the dongle but nothing happens.
am I doing something wrong?
There are currently 1953 users online. 3 members and 1950 guests.
