[ROM] AlfaWise H96 PRO Dongle 2Gb/8Gb - SCV1-ATV 7.1.2 ( ANDROIDTV VERSION )
    WizMeister
    ​​​​​​​You don't have to power the dongle. It's powered enough by male2male cable.
    Does the Dongle have reset hole? If yes, try to push it after connecting male2male to both dongle and PC.
    If You connect it before loading firmware image, is it seen, by the USB Burning Tool?
    An do You have 2/8 or 2/16 dongle?
    ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
      Originally posted by ch3mn3y View Post
      WizMeister
      ch3mn3y
      Hi! Thank you for the quick response (that was fast!)
      it is the 2/16 model. It is not seen by the usb burning tool at any “connection” method. Not before, not after.
      i have also tried to push and to hold the reset button but no luck. I have tried with two different usb male to male cables but nothing happened.
        I can only say by my experiences with H96 Pro Plus (not the dongle), but it's LED were blue after connecting the male2male cable. So there have to be problem...
        Does Your PC sound that an device was connected when You connect the dongle?
        Maybe try with Amlogic Burn Card and use SDcard to flash the Box?
        And it seems that USB Burniing Tool 2.0.8 is best for this Dongle.
        What is important 2/16 is (at least some of them) compatible with 2/8, so if it's not H2, than firmware from the forum (like the one from this thread) should work fine.
          I can only say by my experiences with H96 Pro Plus (not the dongle), but it's LED were blue after connecting the male2male cable. SO there have to be problem...
          ch3mn3y Hi again and thank you again,
          At the Gearbest website it doesn’t say H2 so I guess it is not the H2 model you mentioned. (https://m.gearbest.com/tv-stick-dong...71.html?wid=21)
          I’ll try again tomorrow with the usb burning tool. If nothing happens I will do it with the SD card tool. All this frustration because I didn’t know these “boxes” do not ship with ATV .
            Hi again and thank you again! I do not think t is the H2 model there is no such reference on the product description on GB. I will give it a try again tomorrow and if it still fails I will try with the SD CARD
              Kinda curious if you got this to work on your dongle. Mine is also the 2/16 and I wanna check out this rom on it. If you haven't tried it I'll try it tomorrow.
                I haven't tried yet (I have a 3 m.o. baby so u can guess that it is difficult to find time) so give it a try if you can and let me know.
                  Ok just tried it before work, it's working for me.
                  this is my stick: H96 Pro Android 7.1.1 OS Amlogic S912 BT4.1 TV Dongle https://gearbest.app.link/VT4HZTYNvJ
                    Thank you for the feedback!can you describe what you did?eg which USB port you connected also at which time (before or after pressing the start button etc)
                      I used burn card, same as the box it has the little pinhole on the back. Under the burn card program I ticked everything except the bootloader option.
                        I want to report that using the usb burning tool had no success.
                        So I tried to do it with the burn card which worked!
                        The rom is very fast and responsive!
                        BUT...! I am having a UI-800-3 error on Netflix .. Anyone knows how to resolve this? On the rom description I see that netflix works... but not on my case
                        • superceleron
                          superceleron commented
                          Editing a comment
                          It only works the one that was already in the rom(the mobile one) if you want to use the ATV one forget it, that one only works on L1 devices!
                        #42
                        That’s a putty! Awesome Rom by the way!!! Thank you very much for your hard work!
                          Just installed after running normal version. This version seems a lot faster. Thanks superceleron.
                            Glad you guys like it.
                            That is why i do it, to make this devices a little better for all
                              Hi Superceleron,
                              Another great work.
                              Promo at Gearbest 2/8gb US plug for 30,45$
                              I just ordered it ans downloaded your ROM.
                              Just need to flash it when i will receive it.
