thanks for the support superceleron. The only drawback for me in that TV Box now is the weak Wi-Fi module. My router is just 2,5m from TV and TV Box shows only 2 bars of range..
[ROM] AlfaWise H96 PRO Dongle 2Gb/8Gb - SCV1-ATV 7.1.2 ( ANDROIDTV VERSION )
Guest
I confirm compatibility of this ROM with 2GB/16GB version. I have used burn card method and it works. I had scary moment as after beginning of flashing process the progress bar stuck for some time and I was close to turn it off. I'm glad I have waited as after around 10 min went further. Whole flashing process took some close to 20min O_O maybe because I have used some old slow 2GB SD card
Originally posted by MikeG7 View PostI confirm compatibility of this ROM with 2GB/16GB version. I have used burn card method and it works. I had scary moment as after beginning of flashing process the progress bar stuck for some time and I was close to turn it off. I'm glad I have waited as after around 10 min went further. Whole flashing process took some close to 20min O_O maybe because I have used some old slow 2GB SD card
Guest
urbanman2004
Now I know, and that's sucks..
@trebor
Yeah I did exactly the same thing with my. Wi-Fi antena is outside the box but even with that maximum download speed is 23mb/s on 35mbs internet, when PS4 have also 2,4Ghz Wi-Fi and the speed almost maximum.
Have someone tried to bypass build in Wi-Fi and solder new mobile module from a cellphone?
@trebor
You probably have TWRP already installed. Try to boot it that way - disconnect power cord, start pushing reset button, connect power, keep pushing for 5 seconds or till You see TWRP logo.
MAGISK can be downloaded here: https://forum.xda-developers.com/app...2#post68966662
However if, after flash, You will have FC when launching MAGISK Manager, than uninstall it and install v.5.5.0: https://www.apkmirror.com/apk/topjoh...-apk-download/
Newer seems to not work on my H96 Pro+ (and may not on Your Dongle).
If You cannot boot to TWRP, copy this file to SDcard: https://mega.nz/#!Ji4iEAjI!5iCbS2F9J...cO6-MWb1b-z90I
Put SD into slot in the Dongle and than try with reset button.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Hello,
I install this ROM and is working very well even if i am not used with this ATV interface. I prefer to use a KodiLauncher, and on this ROM it seems i cannot.
Anyway.. the main reason why I tried to use this ATV instead of the Normal Version was the Google Cast Receiver but i cannot make it work.
did someone managed?
Another issue is the Bluetooth... If i connect my Bluetooth Portable Speaker to the dongle it happens something strange... I got no sound but after some time it comes back but it`s not lasting much.
It`s not the Speaker because I tried 2 different Bluetooth Speakers and both off them work flawless my other older Dongle RK3229.
Dose someone else encounter this issue?
I think google cast won;t work on any of the roms. Some limitations of device(s - coz it's not only dongle, but Box as well).
What is the problem with the launcher? If it's that it's not default launcher, than the problem is with how the Android TV is made. Official launcher is the only one that can be set as default.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostI think google cast won;t work on any of the roms. Some limitations of device(s - coz it's not only dongle, but Box as well).
https://forum.xda-developers.com/and...-t2900726/amp/
But this app it's not compatible with nougat
With the launcher I can live but the Bluetooth speaker bug is very annoying!
Hi Superceleron...gret job!!!
I installed your atv version in a 2gb/16gb dongle version and just a few flaws:
Wifi is weaker than the official firmware.
Reboot app installed in firmware does nothing...yo can not reboot or switch off the dongle from that app.
And a question...is FTMC taking advantage of amlcodec in android 7 or from android 6 has no effect?
There are currently 3453 users online. 0 members and 3453 guests.
