[ROM] AlfaWise H96 PRO Dongle 2Gb/8Gb - SCV1 7.1.2 ( "NORMAL" VERSION )
Originally posted by devitrified View PostI'd like to try out this rom but before taking the jump i'd like to make a backup. What method works? I've tried booting TWRP from SD card using recovery-twrp-3.0.2-T95Z.img but no success.
TWRP311_AML_ViT.zip
You must go to update & backup select downloaded file and press update. Device will boot into twrp recovery. That file does not flash your recovery.
Originally posted by superceleron
English plz... this is a english forum.
And yes you can use it... but i dont recommend it!
Android 7.1.1 OS Amlogic S912 BT4.1 H.265 4K?
Sent from my LGMP260 using Tapatalk
Originally posted by wilbigdaddy2000I bought 2 of these and am waiting for them to arrive in a day or two. Will this work for H96 Pro TV Dongle 2GB RAM + 16GB ROM - 2GB RAM + 16GB ROM US PLUG 218464704
ZUK Z2 Pro ✓ᵛᵉʳᶦᶠᶦᵉᵈ
ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
avd
Normal. Too many apps are incompatible (or more even unavailable) in ATV's Play Store. And Leanback Launcher isn't best one.
And normal version still can look (almost is right after flash) like ATV one.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Hi thank you for the rom it's super quick been using it for about a week today it froze for the 1st time when I went to take out power cord the device was hot as so I downloaded CPU monitor I'm getting temp between 73c to 78c. I watch Kodi only sometimes YouTube no playing games. Is anyone having this problem?
wilbigdaddy2000
My mistake, I still live in a world of my BoxSorry
A for dongle I believe there is only one version of it. Than You can flash any of the Rom You want, but I would recommend "Normal" Android - more apps are compatible using Play Store, so it's easier to install them. With ATV if an app is incompatible, than You'll have to get and .apk every time an update comes.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Sent from D.Wil's Magic Carpet
There are currently 3964 users online. 1 members and 3963 guests.
