[ROM] AlfaWise H96 PRO Dongle 2Gb/8Gb - SCV1 7.1.2 ( "NORMAL" VERSION )
H2 and H3 is just a name to tell apart dongles, as they look the same. They all are Alfawise's. H2 has even same SoC like one without "H" in name - S912 (H3 has S905X).
And looking at pictures of H2 on Banggood/Geekbuing it doesn't have H2 logo on it's case. H3 has the "H3" below "H96 Pro", but other two seems to be identical.
H2: https://www.banggood.com/H96-Pro-H2-...p-1187723.html, https://www.geekbuying.com/item/H96-...le-391278.html
H3: https://www.gearbest.com/tv-stick-do...p_1378913.html, https://www.geekbuying.com/item/H96-...le-390198.html,ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostH2 and H3 is just a name to tell apart dongles, as they look the same. They all are Alfawise's. H2 has even same SoC like one without "H" in name - S912 (H3 has S905X).
Don't think there is other one than his and ATV superceleron;s Rom. They may work on Your, but it's Your choice if You are up to trying. I would try if I were You, coz I hate official firmware :P Still there is chance that You will end up with soft bricked device. And I don;t see any official firmware for this dongle, so if You need one, try contacting the seller, maybe there have something.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostDon't think there is other one than his and ATV superceleron;s Rom. They may work on Your, but it's Your choice if You are up to trying. I would try if I were You, coz I hate official firmware :P Still there is chance that You will end up with soft bricked device. And I don;t see any official firmware for this dongle, so if You need one, try contacting the seller, maybe there have something.
I received yesterday this stick:
It says just H96 PRO 2/16. Unfortunately never got it to work as the light is always red and no image on TV. I also tried pressing the reset button for several minutes and nothing happened.
From your post I understood that there is more than one version of this stick with Amlogic S912 and that this firmware only works with the first version. Is this correct? Is there a way to identify this from the outside?
At this time I do not think I have much to lose.
Many thanks
Hey guys! A BREAKTHROUGH!!
I discovered for using widgets ON ANY LAUNCHER!
(Previously only squarehome 2 worked with 'system widget picker' selected in home options)
But after unlocking widgets on my girlfriends Kindle Fire HD 8... I thought.... I wonder if.....
Turns out I was right, its the same fix!!
This works on any AlfaWise without widget support! Not just the dongle we have.... Here goes.....
1. Download a file manager that has ability to view system folder without root like TotalCommander (I recommend my fave... MiXplorer).
2. In file explorer, navigate to /system/bin.
3. Locate file named "appwidget" & COPY this file to internal storage.
4. Long press the file you have just copied to internal storage, then select the RENAME option.
5. Rename the file "appwidget.sh"
6. Now connect your device to a PC with ADB (if you havent got this yet download "minimal ADB & fastboot" its less than 4mb!! Google!)
7. Connect with wire & accept USB debugging popup on device OR
8. Connect wireless with command:
adb connect <your.IP.address.here>:<port number>
(Example)... adb connect 192.168.2.14:5555
(Your IP address can be found in settings-device-about-status. Port is 5555 automatically)
9. Run command "adb devices" it should say connected!
10. Now run this command:
adb shell appwidget grantbind --package <package.name.of.your.launcher> --user <USER_ID>
(An example using my favourites!).....
For Nova Launcher: adb shell appwidget grantbind --package com.teslacoilsw.launcher --user 0
IF NOT it will be: user current
(An example)... adb shell appwidget grantbind --package com.ss.squarehome2 --user current
11. Now run command: reboot.
12. Have fun picking widgets finally!!!
13. Your welcome!
You don't have to connect Box to the PC (step 6-7). If You have Root ofc.
Just install Terminal Emulator app and use this commands:
Code:su setprop service.adb.tcp.port 5555 stop adbd start adbd
And didn't You miss step between 6 and 7? All guides (including Google's) says that after connecting using USB cable You have to use this command on the PC:
Code:adb tcpip 5555
Originally posted by ch3mn3yYou don't have to connect Box to the PC (step 6-7). If You have Root ofc.
Code:adb tcpip 5555
(i stated the "universal" method for ALL devices)
(did say this works on any device without widget support, not just this one, and i actually done this on an un-rootable Kindle Fire HD 8 2017 first!) thought it will be a great help to many people out here!!!
As for the other bit, no you dont have to, "adb tcpip 5555" is the command to start wireless ADB server on the device itself ("adb start-server" CAN be used first to start daemon running on port whatever instead of the command you stated. BUT THIS IS NOT NEEDED... "adb connect" command will start ADB if its not already automatically, yes ADB has some automation! LESS TYPING FOR YOU FROM NOW ON MY FRIEND!!!
An example for YOUR command: (in terminal emulator, on the ROOTED device itself) command "adb tcpip 5555", this starts your ADB wireless server running constantly untill you command to stop it with "adb kill server" it does the exact same as tapping the "wireless ADB" quick settings tile on your phone and having it running constantly BUT THIS IS NOT NEEDED! (and this is a root command also!)
The "adb connect iport" will
A. start ADB if not running already (no need to "start-server") and...
B. once ADB has started, it will then push the "allow debugging from..." pop-up to your device (no need to "tcpip 5555" OR use wireless ADB tile OR option in developers settings etc etc to start wireless ADB on the device at all!
You dont even need ADB wireless tile, a Terminal, Root or to start ADB on either the PC OR the device itself for my method, in fact you dont even need a PC either!!! .....i actually use my rooted Galaxy S5 with Magisks ADB & Fastboot module, open up Termux and then i ADB my devices without the need of a PC at all!!!!
Sent from my H96_PRO_STICK using Tapatalk
Originally posted by Scott.S View PostAs for the other bit, no you dont have to, "adb tcpip 5555" is the command to start wireless ADB server on the device itself ("adb start-server" CAN be used first to start daemon running on port whatever instead of the command you stated. BUT THIS IS NOT NEEDED... "adb connect" command will start ADB if its not already automatically, yes ADB has some automation! LESS TYPING FOR YOU FROM NOW ON MY FRIEND!!!
Still it seems useful to have ADB always on, as TV Box is something, which, I think, most people keep in room without PC.
Not 100% safe, but as long as someone doesn't hack Your network, You should be safe.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 1685 users online. 1 members and 1684 guests.
