This is a great little device, really nice!
Many thks to gearbest for sending me the device to play
Thks trebor for the beta test!
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
WATCH OUT IF YOU PROJECTOR IS ALREADY ON ANDROID 6 IT MEANS IS A S905X CHIP, DONT TRY THIS ROM BECAUSE IS ONLY FOR THE S905 VERSION OF THE PROJECTOR.
Changelog V1:
- based on stock!
- Added Twrp 3.1.1 recovery
- unrooted ( Yes now you can install magisk or whatever you use to root, use the included update app to flash it! )
- Big optimization, is really fast now and i mean fast... you will see it!
- Navigation should be smooth as silk and fast.
- New Boot Logo, many thks to danielelek90 for the great work
- Netflix, youtube, playstore...etc... fully working
- Added lighthome launcher
- Removed the force use of their launcher!
- Fixed UI crashes
- Projector Brightness to max by default
- PS3/PS4 gamepad support ( only with cable... )
- Added Xbox360/XboxOne gamepad support ( cable, wireless and Bluetooth )
- Added Dragonrise USB HID game controllers.
- Wifi connection speed should be a little better.
- Permissions fixed. ( lots... )
- Many KL's added.
- Fixed AMCODEC playback. ( Lot's of playback fixes )
- - Brightness and contrast can be controlled in FTMC, possible others!
- Some audio mods.
- FTMC Build 31
- Some video optimizations ( tested in two different's online ISP's TV and both give HD streams just fine )
- Optimized some animation stuff!
- Added Android TV screensaver ( default 5 min )
- Added a setupwizard.
- And other stuff under the hood!
- In youtube app when you search if it ask to access you microphone deny it or else it will crash.
- In setupwizard you see the letter are big, cant do nothing about it, is hard coded like that... you can change the size of the letters in settings but since this is a projector you going to regret doing lol
- Possible a lot more!
Want to buy me a beer?
Download SCV1 IMG:
- DOWNLOAD HERE IMG SCV1
- MD5: 34123EB54DE86835992D6C800286707B
Install instructions:
- Use usb burning tool....
- PRESS HERE TO DOWNLOAD A PDF TO EXPLAIN HOW TO FLASH THIS PROJECTOR!!!
Where to buy:
1ยบ BOOT MAY TAKE +/- 6 MINUTES!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
