H96 PRO Plus - and other cool hardware mods
My mod, screwd it into a psu box and used 12v fan( will order 5v soon) and big heat sink . temperature is 43c in normal usage and never crosses 53c no matter what i throw at it. While just let the shitty wifi connector( thinking of soldering a new wifi antena) out for maximum possible signal strength.
Sent from my SM-A310F using Tapatalk
Hi ,
WoW , looks interesting , some Pictures from the inside Mods would be nice ,
nice Work ,
greetings / gefattern
The assembly is very simple. I removed the old radiator, I applied the thermopad and applied the water block (it is not attached to the housing with any screws). I adjusted the hole in the housing (after removing the shiny surface with the inscription 4K). I simply put the H96 Pro Plus on the Thermaltake radiator, which I also highlighted the LED (just like the water pump). To power the LED and pump, I used a small 5V / 12V power supply with a molex connector (from an IDE / USB adapter)
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
did you build this cooling Unit by your own , Homemade , or bought ,
nice would be a TVBox PCB inside Water , like already done with PCs ,
Hi ,
I bought a water block, a pump and a cooler separately in various stores. I had to look for a water block for a long time to be small, but also to have transparent plexiglass. I assembled the whole myself and made LED backlight with elements purchased in an electronics store. I was looking for inspiration on the internet, but I think nobody has done anything for this TVBox yet. I'm glad that you like it
i really interested in a full Water Box , with electric free Water ,
already seen with PCs , if i could restore my old UT3 , i could
make a double Deck with my UT4 ,
My new transparent box- i dont really like the notion of punching holes in original box plus the height of stock box is really small to house a big heat sink so got myself a this plastic box. Used old pc heat sink and really powerfull but tiny 5v 0.16a/fan (a bit noisy though).
There are currently 1607 users online. 3 members and 1604 guests.
