H96 PRO Plus - and other cool hardware mods
Originally posted by chenrp View Post
it is a part of the antenna
Edited: The casing is really annoying. It was a bit difficult to pry it open, but it is a lot more difficult to put it back together. Any ideas for a custom casing? Was looking through some bread board but they all look hideous. I'm not yet ready to use my desktop casing as the pc is still working.Last edited by BlackBriar56; 12 October 2017, 21:34.
Originally posted by muncheno View Post
Nice mod.
It is nicer if you hide power cable inside.
I just did this and testing the unit for now. Will be playing terrarium for hours to see if it holds up.
I have a bluetooth mini keyboard so I can hide the box behind the tv.
This fan is usb driven. Hooked it up to the secret USB port.
Temperature is around 42*C after an hour or so.Last edited by panchovilla; 13 October 2017, 02:33.
Originally posted by Agronur View PostI plan to change heatsink with bigger one with fan and as i see default heatsink planted with two sided tape. How can i remove it. I didnt do anything like this. I am afraid of making mistake.
Didn't even notice there's a hookup for a fan inside. I'm gonna have to work on hiding the wire and wiring the fan inside.
A Raspberry Pi3 fan and heat sink kit might be the ticket.
There are currently 1891 users online. 0 members and 1891 guests.
