H96 PRO Plus - and other cool hardware mods
Originally posted by chenrp View Post
Yep. It is a logo replacement made out of aluminum and with thermal pad touching the modified heatsink
Latest cooling mod. I tried a tiny fan first, worked fine but it spun at 3000rpm and emitted an annoying whine.
This is made from packing foam with cutout sized to accept a 5V laptop cooling fan. The foam is stuck to the case with 2sided tape at each corner. The fan is just press fit in place. I'ts purposely left protruding to create a chamber underneath. When I push the fan all the way down temps increase a few degrees. The alfawise logo strip is removed and heat sink replaced with a larger one with 3M thermal transfer tape. This fan moves the same CFM of air as the smaller fan but spins slower so is nearly silent. It's powered from a USB port on my Home Theater System.
Idle temp 28-30C, Watching HD video 34-37C
I also changed the stock 2.5A power supply for a 4A model. It doesn't even get warm.
Edit: I measured the current draw of the USB fan. It draws 0.08 amp (80 ma)You may only view thumbnails in this gallery. This gallery has 6 photos.6 PhotosLast edited by imaddiced2u; 16 November 2017, 10:45.HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by mcerk02 View PostThis is my cooling fan mod, https://imgur.com/a/JmvjG
Originally posted by panchovilla View Post
That is a big fan. That might drain the board and the power adapter. Get a more powerful adapter. At least 3A output. 4-5, even better.
I did consider this when I put the fan on but never got around to getting a larger power supply, haven't had a problem so far though, been running it like this for a few months now and I use it almost daily....
HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
There are currently 2547 users online. 0 members and 2547 guests.
