{ROM} New Firmware: Sunvell T95Z Plus TV Box Android 7.1.1 with ROOT
    Hello Guys
    Finally i found Android 7.1.1 for Sunvell T95Z Plus TV Box
    Download from this link
    https://www.dropbox.com/s/3huy9anrm6...ction.rar?dl=0
    To install the new firmware
    1- download Burn Card Maker
    https://www.dropbox.com/s/jejlf6xuw2...Maker.rar?dl=0
    2- connect SD Card to your pc
    3- open it and check everything then choose format as force
    4- click make and choose the firmware image file
    5- it will ask you to format the SD Card after you finish it will start automatic to create the SD Card with the new firmware
    6- connect the SD Card to your TV Box
    7- remove the power then connect the power again it will start upgrading automatic ( if the upgrade not starting then bring anything to put it in the AV hole you will feel click then connect the power it will start automatic )
    now after it finish keep it for around 3 minutes and you will have the latest firmware 7.1.1
    Update Thanks to Ramirez7 for his help about how to root the firmware without any problem
    and here is the steps
    first download this apps
    after downloading format your SDCard and then copy this files to SD Card root
    2- go to your apps and choose the update app with the blue arrow
    3- click select and choose twrp.q20x-3.1.1-0-signed.zip then click update your tv box will restart
    4- it will open TWRP click install and choose your SD Card and click UPDATE-unSU.zip after that click reboot
    5- repeat step number 2 and 3
    6- your tv box will restart and open TWRP click install and choose Magisk-v14.0 after make reboot
    7- your tv box will open and you will find it rooted
    What is the firmware for room 2gb or 3gb and what type of wifi chips?
      It is 7.1.1 rom v. 1013 for 2G version with AP6255.
      This is from it's build.prop:
      ro.build.display.id=T5ZP1013
      ro.build.version.incremental=20170628
      ro.product.board=q201_6255
        Thanks for finding this Rom! Finally Android 7.1.1!
          Thank you very much!! It works with AP6255 AMPAK WiFi chip. Just still the issue with the old firmware, that when I hide the bottom (navigation tab) I cannot get it back until restart .. anyone knows how to fix it?
            I can't install it wit SD card because I had superceleron installed with TWRP. I switched to stock recovery but everytime recovery says "E: Cannot load /misc". What can I do? Can someone give me a copy of your stock recovery?
              Try to use usb instruction that included with the firmware there is PDF file about how to use USB and let me know if you have any problem
                Does not work. My PC doesn't recognize the TV Box in any way.... :/
                  This firmware was posted nearly 8 weeks ago
                    Originally posted by ELMOHTARF View Post
                    Hello Guys
                    7- remove the power then connect the power again it will start upgrading automatic ( if the upgrade not starting then bring anything to put it in the AV hole you will feel click then connect the power it will start automatic ),
                    I have only one problem after upgrading i try to make root by installing supersu from playstore but it make the device stuck after first reboot so be careful
                    if any one can help with rooting 7.1.1 it will be good
                    I uninstalled su with unSU.zip and flashed magisk works well for me
                      http://freaktab.com/forum/tv-player-...55-help-needed
                      ya i saw this one but this is for 3+32 not for 2+16
                      i try to use this one with T95ZPlus 2+16 and stuck
                      this is for 2+16
                        Now it works with USB Burning Tool neqest Version. Android 7.1.1 is great! I always try to do a flashable Rom in ATV style.
                          very good but did you used a custom recovery like TWRP
                          or you can post the steps how you made root for this firmware ???
                            get twrp.q20x-3.1.1-0-signed.zip put in sd card and other files in a usb drive, http://freaktab.com/forum/tv-player-...devices/page92
                            In the device update apk you select the temp twrp zip as update file, you get rebooted in temp twrp environment, flash unsu.zip to remove supersu and then flash magisk , i have v14
                              ELMOHTARF, the 2gb version is on the same page, been using it for 7 weeks. It's OK. Been on 7.1.2 for mk22 last few days which is good apart from can't change launcher, no clock & can't turn on with remote. Will go back to T95z firmware when it next gets updated.
