{ROM} New Firmware: Sunvell T95Z Plus TV Box Android 7.1.1 with ROOT
Originally posted by Boneo View PostELMOHTARF, the 2gb version is on the same page, been using it for 7 weeks. It's OK. Been on 7.1.2 for mk22 last few days which is good apart from can't change launcher, no clock & can't turn on with remote. Will go back to T95z firmware when it next gets updated.
but this is the official firmware for t95z plus 2+16 and work fine with the device
Originally posted by binarstorm View PostThank you very much!! It works with AP6255 AMPAK WiFi chip. Just still the issue with the old firmware, that when I hide the bottom (navigation tab) I cannot get it back until restart .. anyone knows how to fix it?
Originally posted by Ramirez7 View Postget twrp.q20x-3.1.1-0-signed.zip put in sd card and other files in a usb drive, http://freaktab.com/forum/tv-player-...devices/page92
In the device update apk you select the temp twrp zip as update file, you get rebooted in temp twrp environment, flash unsu.zip to remove supersu and then flash magisk , i have v14
that method don't work for me. I select the temp twrp file, click on update, the box reboots and says error....
Any ideas? :/
Originally posted by Manta View Post
Hey,
Any ideas? :/
also found this https://forum.xda-developers.com/and...-plus-t3557812, but havent tried
try with this twrp: https://mega.nz/#!kR8Qyb5Z!ppLHfbaOf...vTtv4g6Xf8nOAU tested it now and works
Another problem, it doesn't work too...
After "Run TWRP recovery 3.0.2 as application" it freezes and reboots to TWRP again and this doesn't end. :/
Kodinoob this firmware is also stock , remote works fine
There are currently 2007 users online. 3 members and 2004 guests.
