{ROM} New Firmware: Sunvell T95Z Plus TV Box Android 7.1.1 with ROOT
Originally posted by Ramirez7 View Post
try with this twrp: https://mega.nz/#!kR8Qyb5Z!ppLHfbaOf...vTtv4g6Xf8nOAU tested it now and works
also found this https://forum.xda-developers.com/and...-plus-t3557812, but havent tried
Originally posted by GolfG60 View PostRamirez7 this does not work! I put .RAR file in SD. and updated with the UPDATE app. On xda I searched for other files. but I am .ISO and do not find them in the UPDATE app
after downloading format your SDCard and then copy this files to SD Card root
2- go to your apps and choose the update app with the blue arrow
3- click select and choose in this case (20170816133938_S905_TWRP3_ViT.zip) then click update your tv box will restart
4- it will open TWRP click install and choose your SD Card and click UPDATE-unSU.zip after that click reboot
5- repeat step number 2 and 3
6- your tv box will restart and open TWRP click install and choose Magisk-v14.0 after make reboot
7- your tv box will open and you will find it rooted
Hi all, been trying out ugoos am3 7.1.2 beta firmware( http://freaktab.com/forum/tv-player-...-for-ugoos-am3) which is very good, WiFi is for q6(or 9)377 or something so no good to me but I don't use it or Bluetooth. Has anyone else tried & got T95Z remote.config to work for it? Just the power on issue. I don't think our boxes will ever get stock firmware as good as the am3 beta to be honest.
Originally posted by Boneo View PostHi all, been trying out ugoos am3 7.1.2 beta firmware( http://freaktab.com/forum/tv-player-...-for-ugoos-am3) which is very good, WiFi is for q6(or 9)377 or something so no good to me but I don't use it or Bluetooth. Has anyone else tried & got T95Z remote.config to work for it? Just the power on issue. I don't think our boxes will ever get stock firmware as good as the am3 beta to be honest.
Y
There are currently 2971 users online. 4 members and 2967 guests.
