The ROM is an Android TV by default (but with mecool launcher), completely disables the nav bar. Normal android apps needs to be sideloaded because play store now has only access to ATV apps.
Firmware Stock OTA & .IMG UPDATE FIX MECOOL M8S PRO PLUS ANDROID 7.1.1 AMLOGIC S905X 2GB/16GB
Please I need help... Today when I got home my box does not start ... my son is always "playing" with her and probably did something ... Does anyone know how I can do to "re-enable" ??? What software use and how to use please ... I am very new to this and I do not know how to do ... Thank you
Originally posted by P.X View PostRef. steel120
Found 2 eMMC Apps -
eMMC (Brickbug) Check -&- Got Brickbug ?
Reports are ref. Old Sammy phone and recover a code
Research seems to suggest CODE:
AJNB4R = SEC KLMAG1JENB-B041 (v5.1) = Known BAD Check DATE
AWPD3R = SAMSUNG KLMAG2WEPD-B031 (v5.0)5 = OK
8WPD3R = 8GB
S10016 = Kingston eMMC v5.0 - 16GB = Good So Far !
eMMC Check - also returns a Chip build date - MM/YYYY
The Date Code on the physical chip is YWW (e.g.646)
646 -> 11/2016
SEC 701 to 713 presumably return 01/2017 - 04/2017
(note 04/2017 covers more than just 713 therefore box would still need to be opened for final confirmation of possible chip issue)
E&OE
Does this means I can't even try placing some other rom, this is bad chip?
(btw is there any downsides of having this chip except not been able to change fw)?
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by ag008 View Post
Also 0919 is OK FW
so fingers crossed ....
Originally posted by peta18 View PostHi, can anyone help me how to dump stock rom and make an img file? I have an usb cable and I can connect my box to my pc but I don't know what software I can use to do this.
Originally posted by zabba View PostHi, i am having what i believe is a HDMI blinking problem (intermittent flickering) on my new samsung mu6120 with my box. I am using the 20170919.150557.V0619 stock firmware. Is this issue to do with my box (firmware) or my tv? ThanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Try starting your box first, then your TV.Â* It is a handshake problem.
Hi, i tried switching the box on 1st before the tv to see if it that would solve my hdmi handshake problem but it was still doing it so i have switched the hdcp setting to off in the developer options now. I havent been testing it long but i have had no flickering up to now, is there a downside to switching hdcp off? Cheers.
Originally posted by tantrums View Post
Successfully updated my box w/ SEC 713 8.15 firmware by using continuously pressing "1" key on the remote control while powering up.
Does this stock firmware run Nexflix ATV version at 1080p?
Will auto refresh rate work with SPMC (with root and maybe some modification)?
PS. now I'm using Magendanz's ATV rom but sadly auto refresh rate will result in black screen.
There are currently 806 users online. 1 members and 805 guests.
