Firmware Stock OTA & .IMG UPDATE FIX MECOOL M8S PRO PLUS ANDROID 7.1.1 AMLOGIC S905X 2GB/16GB
Originally posted by bylderup View Postjust my 2 Cents..
I´ve got a box from geekbuying with the faulty eMMC . So I decided not to change the ROM. Its used in a room with only 2 channel Sound. FTMC and SPMC are running fine, Youtube ok, Spotify ok. On SD Card Libreelec. All working. Sometimes in Android a restart is needed because 2 Cores stay at 100 %. Absolute no problems with Libreelec. 31 Euro paid and running better than my expensive TV Boxes. So what.. I will use Super Celerons excellent ROMS next time
For German Customers it is hard to get TV Boxes from China atm. because Gearbest and other shops have massive problems with "Germany priority mail". A lot of devices have been catched from Tax Authorities in London. I´m waiting 4 weeks now getting my Mecool KI pro. No clue if I will ever get the box.
If I would order the Mecool M8S pro + now - then total costs will be in the end at about 50 euro (with DHL incl. Tax and processing fee) on a more secure delivery route. So - wait and see..
Originally posted by grimmie View PostI believe PayPal will resolve it since geekbuying didn’t respond to you and u already dispute with PayPal.
MeCool M8S pro +
Has anyone come up with a potential list of where to acquire a version of the MeCool M8S pro + with the recommended eMMc to work with the ATV Rom?
my unit came with the SEC 713 which is one identified as a suspect bad memory module. Thus it has failed since I found out too late about the flashing of FW.
Tried LibreElec does not want to work with this either. My unit does have a reset button.
Here is what I received order was a GearBest purchase late Sept time, arrived around 7 October 2017
MeCool M8S pro +
Kernel Version 3.14.29
Tuesday Aug 15 18:31.44 CST 2017
Build
M8S Pro + userdebug 7.1.1 NMF26Q
2017 0815.182813.V0321
OTA
Model M8S Pro +
OTA 90633006
Looking for a source to reorder and try again, I see a 905W model being offered, but not sure if it will play nice with ATV Rom.
Thanks in advance..You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
As Found:
Glad to share the firmware for MECOOL M8S PRO Plus TV Box.
PC Flash Firmware
M8S_PRO+-NHG47L-20170919.150557.V0619.img
SD Flash Firmware:
SD Flash Firmware 1;
SD Flash Firmware 2;
SD Flash Firmware 3.
Flash guide, please refer to: http://blog.geekbuying.com/index.php...utorials-tool/
Have fun !
Tips: Recommend you use SD card brush. The method is that copy SD flash firmware 1,2,3 to the SD card root directory, and then put the SD card on the machine, plug in the power supply. Continuously press the remote control on the number 1 key, then you can automatically enter the state of the brush machine.
Due to the mistake of Mecool,the old firmware lack of some files.
so customers will cause some problems.
It is the newest firmware
source blog.geekbuyingLast edited by trebor; 20 October 2017, 19:52.
Thanks, when i tried to add the normal play store previously it wouldnt work. It said it is incompatible with my device and to uninstall updates and when i did this it reverted back to the android tv version.
I've now downloaded the aptoide app so I'll use that as well as play store for the apk's i cant download on google play store. CheersLast edited by zabba; 17 October 2017, 15:29.
Ref. steel120
Found 2 eMMC Apps -
eMMC (Brickbug) Check -&- Got Brickbug ?
Reports are ref. Old Sammy phone and recover a code
Research seems to suggest CODE:
AJNB4R = SEC KLMAG1JENB-B041 (v5.1) = Known BAD Check DATE
AWPD3R = SAMSUNG KLMAG2WEPD-B031 (v5.0)5 = OK
8WPD3R = 8GB
S10016 = Kingston eMMC v5.0 - 16GB = Good So Far !
eMMC Check - also returns a Chip build date - MM/YYYY
The Date Code on the physical chip is YWW (e.g.646)
646 -> 11/2016
SEC 701 to 713 presumably return 01/2017 - 04/2017
(note 04/2017 covers more than just 713 therefore box would still need to be opened for final confirmation of possible chip issue)
E&OELast edited by P.X; 17 October 2017, 21:29.
I bought my Mecool from Gearbest and this is what I've got:
Samsung 710 KLM8G1WEPD-B031
BuildNO: NMF26Q 20170715.093046.V0321
Sometimes apps freeze (especialy Chrome) and get "app stopped working" massage. I don't think my chip is from this bad batch, 'cause it is eMMC 5.0.
Does anyone have the same chip and did make an update?
There are currently 1963 users online. 0 members and 1963 guests.
