Many thks to gearbest for sending me the device to play
Many Thks to my beta tester trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
Changelog V1:
- Based on stock but only 40%...
- General optimization, should be smoother, faster
- Some house clean!
- Mem usage lot better now.
- Cpu temp should be better, but this box is a heater.... lol, but it better...
- 720p Ui for a smoother and faster experience ( Dont worry it wont affect the view framebuffer )
- Youtube 4K support
- TWRP 3.1.1
- Added a setup wizard.
- Organized some boot scripts.
- Custom Wetek WebOs launcher (Many thks to wetek for let me use it)
- - Menu Button is king on this launcher, its used to add remove icons on the main screen, also to remove widgets.
- - Long press on the default icons on desktop you can change them to other apps (White Logos...)
- - Long press on the icons you add to the deskop and you can rearrange them.
- Added lots of kl's.
- Netflix, youtube, playstore...etc... fully working.
- Many Gamepads supported.
- Lots Permissions fixed.
- FTMC Build 31 ( ENABLE ALL RKCODEC OPTIONS IN SETTINGS )
- Fixed RKcodec Playback and fractional HDMI in FTMC. ( Fractional HDMI Only works in the 3328 and 3399 )
- Added a few apps...
- And some other little tweaks...
Bugs V1:
- Don't try Magisk, it wont work!
- Possible lot more Bugs...
Want to buy me a beer?Download:
- DOWNLOAD HERE SCV1 for the SCISHION V88 Mini III
- MD5: 2854A8BAD51EEED21728959DB9C500CA
- Search the forum for instructions, is the same as all other rk boxes...
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
