[ROM] SCISHION V88 Mini III 2Gb/8Gb - SCV1
Originally posted by RedEyes View PostGood morning,
Superceleron thank you for your fantastic work.
One question, can I use this Rom for the scsion v88 V88 NO? is the same product, only difference is the ram 4/16.
Thanks Best Regards
Also notifications swipe down doesn't work nor do the normal navigation bottom line (with the circle, house, and pages icons) show up. So its pretty hard to do a lot of things. But I think these were also defects in the stock rom so if that was used as the basis for this one then it would make sense.
superceleron i crashed it and I'm trying to reinstall the *.img file thru twrp's "install" option. Can you tell me which partition I'm supposed to flash it on?
the options are:
Uboot
Trust
Resource
Kernel
Boot
TIA,
-Kevin
Originally posted by superceleronThe img is to be burn by usb with the tool for windows!
Sent from my LG-M210 using Tapatalk
I installed the snowball notification manager with aptoid (its not on playstore) and it allowed me to turn on notifications for the wetek launcher as well as it (otherwise unreachable best I could tell through the settings) and that gave me icons on the launcher plus a nice pull down notifications tool so that helps a lot.
Still strange that I can't get the navigation panel up off the bottom plus so much of the settings are unreachable unless an app is installed that initiates it for its own purposes.
FYI, the snowball notification manager appears to deaden things near the top of the screen (for its pull down) such as browser tabs. They still work but you have to click on the bottom of them.
Also, I was able to access turning on the Wetek launcher's notifications thru its setup age (house with gear icon) (but not thru android's regular settings anywhere I can tell).
Â
Hi, Superceleron, I bought a piano version of this Mini III which spec is 4G ram + 16G rom + RK3328 chip, from China market, the firmware preinstalled is date Nov 2017 but it's crappy, are u able to form-up a new firmware for this spec, I think just modify your 2G+8G version firmware will do. appreciate your reply.
Hi superceleron any idea why I can't seem to get HP printing going no matter what I try?  I think maybe its because I can't enable the hp print service plugin thru the settings menu.  There doesn't seem to be any path to it via settings.  I'm not really getting any error messages in the logs either other than
PrintManager
Feature android.software.print not available.
no app menus show print except for acrobat (which doesn't do anything nor work).
Only occasionally does a print option show up under the share menu (and it also does nothing nor does it work).
TIA,
-Kevin
Originally posted by nightshark View PostHi, Superceleron, I bought a piano version of this Mini III which spec is 4G ram + 16G rom + RK3328 chip, from China market, the firmware preinstalled is date Nov 2017 but it's crappy, are u able to form-up a new firmware for this spec, I think just modify your 2G+8G version firmware will do. appreciate your reply.
Its also nice to have TWRP installed to recover, do backups, etc...
Don't forget to go into the launcher's settings and enable notifications (and/or install snowball).  That helps a lot in knowing what's going on.
Originally posted by kevinfish View Post
I'm running this ROM on my v88 piano.Â* Â*Since its based on the original crappy ROM a lot of the stuff that didn't work there still doesn't work, but in spite of that IMO its a big improvement (for performance reasons if nothing else).
Don't forget to go into the launcher's settings and enable notifications (and/or install snowball).Â* Â*That helps a lot in knowing what's going on.
There are currently 2755 users online. 0 members and 2755 guests.
