Electrons are just electrons. Just make sure the wall wart provides enough amps at the same voltage and is also D.C.
[ROM] SCISHION V88 Mini III 2Gb/8Gb - SCV1
Hello superceleron , I've installed your ROM in mi Mini III, and everything is fine untill I try to add a Google Account. Wherever I try it, via Google Play, Chrome, Settings->add account (Google) and any other methods, the "login" button do not work, it do not show a window to insert the credential of the account.
There's a solution for this? Thanks and regards!
Originally posted by RugaL View PostHello superceleron , I've installed your ROM in mi Mini III, and everything is fine untill I try to add a Google Account. Wherever I try it, via Google Play, Chrome, Settings->add account (Google) and any other methods, the "login" button do not work, it do not show a window to insert the credential of the account.
Thanks for the rom, is awesome, superceleron !
good day
my v88 mini III (2018-03-27) XT-RX4_V11 out of nowhere to be using it rebooted and from there it did not start again staying in red light.
I already tried to turn it off and reset without success then I began to investigate how to flash it to get it out of the birck, my computer if it detects it with the RK batch tool and driver install 4.4 like other equipment that has been flashed but when doing the process it presents the following image:
I have a T9 4GB/64GB TV BOX (RK3328) TV stick, it got bricked. I searched the internet and tried many methods to recover it, but failed, please help if you know a better solution.
I used RKBatchTool to restore it, and got a blue square, but after I click "restore" button, it failed at "Prepare idb fail"
I also tried RK Android Tool, my stick is loaded as "Found one MASKROM Device". I played around the tool, but every time it failed at the same reason "Prepare idb fail ".
I have no ideas, anyone please help!
There are currently 2437 users online. 1 members and 2436 guests.
