Z66X Z2 TV Box - ZX296716 Quad-core Android 2/16GB ROM 7.1 2.4G WiFi 100M RJ45
Hi.
My Z66X Z2 device is 2GB Ram 16GB Rom.
and
Firmware
https://mega.nz/#!G9ti2CKK!HTw1VQGFO...3TqMOgDPppQbqU
Unable to load.
the upload is not successful
Is there any other software?Last edited by halilyil; 11 January 2018, 09:41.
I own a box and it's just on the "OK" side of things. Using Nova launcher, output 720p because more wasn't usable on several streaming sites. Wifi is bad but stable if close enough to router. Short range and slow 10-20Mbit/s 5m from router. Even with Ethernet cable I can't get the 100Mbit, more like 80-85. (fiber hookup). Streams often start with bad quality, and might need 10s or stop/start to to kick into higher.
USB ports, not sure what's going on there. Tried to copy a 1.5GB file usb to internal memory and speed was 150 Kb/s.. Had a few crashes, almost random. App might crash but start again and do same action, now it works. Google photo app crashed to name one. Had one big crash, box died and rebooted while playing a video file via Kodi. And pre-rooted means I can't use all apps, some settings in dev-options crash the box. it's like they picked a firmware by random and forced it onto the hardware!
On the positive, it's pretty fast, didn't cost too much and doing what I bought it for. But I hope they release a new firmware (Got my box Dec 22, pre-loaded with 1.0.0.2). Looks like manufacturer is here https://zkmagic.en.alibaba.com/conta...2b902dad0jghmM and on facebook https://www.facebook.com/ZkmagicTVBOX/
I replaced the horrible internal antenna which sometimes would drop below 5 mbit download speed. Internal design is basically just a bit of tape with some copper on it. Soldered on external omni-directional antenna from old router and now get much better and stable wifi. But max out at about 36 Down and 43 Up. Not close to 150 Mbit as advertised. Btw I contacted the manufacturer but they showed no interest in trying to support end user.
There are currently 1631 users online. 0 members and 1631 guests.
