Z66X Z2 TV Box - ZX296716 Quad-core Android 2/16GB ROM 7.1 2.4G WiFi 100M RJ45
Originally posted by suarez23 View PostI also forgot to ask about external antenna. Do I need to unsolder internal antenna to use external one or I can use both?
Hello, everyone. I'm new to this site and very glad to found Z66X forum after buying the box from GeekBuying last month. Still on the connection topic, I put the box on wired ethernet but I have never been able to get decent connection, just 20 Mb/s tops for download (I have fibre 100 Mb/s). Connected with the same cable and on the same port, I can get max speed on my very laggy Windows 10 laptop. Anyone know the settings/tweak to crank up the speed? Thanks.
Originally posted by levi_ray View PostHello, everyone. I'm new to this site and very glad to found Z66X forum after buying the box from GeekBuying last month. Still on the connection topic, I put the box on wired ethernet but I have never been able to get decent connection, just 20 Mb/s tops for download (I have fibre 100 Mb/s). Connected with the same cable and on the same port, I can get max speed on my very laggy Windows 10 laptop. Anyone know the settings/tweak to crank up the speed? Thanks.
Originally posted by tangoviking View Post
20 is low but with these type of boxes do not expect more than 40 Mbps. I'm getting 35-40 max on 100Mbit fiber-LAN with Z66X on default settings. One common problem with many android boxes is bad sheilding so maybe try not to have wifi on and other electronic devices that can influence circuits.
As Found
Z66X Z3 ZXIC ZX296716 2GB/16GB ANDROID 7.1 TV BOX FIRMWARE UPDATE 20171223
PC Flash Firmware
http://geekbuying.mediafire.com/file/7ws4bix4cm19rj0/Z66X_Z3_ZXIC_ZX296716_20171223.rar
Originally posted by trebor View PostFlashed OK
Once I recalled what program to use and find it on the HDD, then how to use it again been awhile
No changelog YT still 720, UI running 720, still ok for what it is.
hy
anyone still active in this thread?
i got the rebranded 8GB version of this box:
might there be a z66 firmware for 8gb device somewhere maybe trebor knows? )
ui is finer than here on globmall
btw from what i read cpu from these boxes here is similar to s905x
but the big advantage is that this cpu during usage, streaming, browsing, is at least 15 degrees celsius below those s905x/s905w cpus
without cooling here 53 celcius where 905 boxes easy hit the 70
with a fan below the box wings towards bottom not box 40 degrees stable while netflix evening, thats just great
There are currently 1711 users online. 2 members and 1709 guests.
