you have been unable to load maybe as you have 16gb rom version, name of the file includes 2+8 so it should be the 2(gb ram) + 8 (gb rom) firmware (which i might use on my globmall 2/8)
Z66X Z2 TV Box - ZX296716 Quad-core Android 2/16GB ROM 7.1 2.4G WiFi 100M RJ45
i got issues with this box, rebranded globmall, but same hardware
only netflix is fine,
youtube and kodi/vavoo give me desync audio is seconds behind video
have to say that i use this box to get netflix/youtube on an old tv, no flatscreen so i use 3 times cinch 3,5mm red/white/yellow to get sound and picture
would think it is an hardware issue but strange is netflix works fine synced out of the box
only auto detected resolution is PAL for sure
any idea how to get off that desync in all the other apps?
Also have this Z66X Z2, 2/16, came with last FW..., but in IPTV (Perfect Player, IPTV Pro...) HW decoding is slow and audio is out of sync....., on SW decoding audio is in sync...
In Kodi also, most IPTV channels are with out of sync audio....
Has somebody some fix for this, better FW, or whatever can help...
With some work and effort I got the files.
But now I have a small problem, if anyone can help I would be very grateful.
Basically even after installing xprog my pc still does not detect the driver. Detects but appears with the yellow triangle. Does anyone have the drivers for the Box?
Thank you all
Tool and Firmeware:
There are currently 2433 users online. 0 members and 2433 guests.
