Firmware aml_7.1_s912_q9377-H96PROPLUS_KDMC_mac-20171010
    Its in
    H96 Pro+ Firmware (Hcygood)
    This isnt the S912 Unbranded Hcygood firmware but new H96 Pro+ Branded Hcygood Firmware
    This is only for cz-s32-v5 boards with LPDDR memory and will brick other boards due to the bootloader
    I have made a build with the normal bootloader for everyone else
    read the 3 posts below
    Code:
    # begin build properties
    # autogenerated by buildinfo.sh
    ro.build.id=NHG47L
    ro.build.display.id=NHG47L.20171010 test-keys
    ro.build.version.incremental=20171010
    ro.build.version.sdk=25
    ro.build.version.preview_sdk=0
    ro.build.version.codename=REL
    ro.build.version.all_codenames=REL
    ro.build.version.release=7.1.2
    ro.build.version.security_patch=2017-05-05
    ro.build.version.base_os=
    ro.build.date=2017年 10月 10日 星期二 18:29:03 CST
    ro.build.date.utc=1507631343
    ro.build.type=user
    ro.build.user=mly
    ro.build.host=czkj
    ro.build.tags=test-keys
    ro.build.flavor=q9377-user
    ro.product.model=H96 PRO+
    ro.product.brand=Amlogic
    ro.product.name=q9377
    ro.product.device=q9377
    ro.product.board=q9377
    # ro.product.cpu.abi and ro.product.cpu.abi2 are obsolete,
    # use ro.product.cpu.abilist instead.
    ro.product.cpu.abi=arm64-v8a
    ro.product.cpu.abilist=arm64-v8a,armeabi-v7a,armeabi
    ro.product.cpu.abilist32=armeabi-v7a,armeabi
    ro.product.cpu.abilist64=arm64-v8a
    ro.product.manufacturer=Amlogic
    ro.product.locale=en-US
    ro.wifi.channels=11
    ro.board.platform=gxm
    # ro.build.product is obsolete; use ro.product.device
    ro.build.product=q9377
    # Do not try to parse description, fingerprint, or thumbprint
    ro.build.description=q9377-user 7.1.2 NHG47L 20171010 test-keys
    ro.build.fingerprint=Amlogic/q9377/q9377:7.1.2/NHG47L/20171010:user/test-keys
    ro.build.characteristics=mbx,nosdcard
    # end build properties
    be careful with this image it says LP in the name i presume low power ddr3?
    my ddr3 board isnt outputing anything as soon as it flashed the bootloader via sd card
      Ok i couldnt unbrick it with the usb burning tool kept saying Romcode/Switch status/Identify/Error result
      after sending UBOOT.USB & DDR.USB (4%) (with the 20170826 Image)
      the way i unbricked it was to make an sd card image of the 20170826 firmware
      it came straight up with the sd card image and proceeded to flash
      so whatever bootloader it came with its not compat with my ddr3
      i will flash this firmware in a sec keeping my old bootloader
        I have done a level 1 unpack of the image and inserted
        aml_sdc_burn.UBOOT
        bootloader.PARTITION
        DDR.USB
        UBOOT.USB
        aml_7.1.2_s912_q9377-H96PROPLUS_KDMC_mac-20171010(Shonk).rar has the bootloader from aml_7.1.2_s912_q9377-H96PROPLUS_KDMC_mac-20170826
        aml_7.1.2_s912_q9377-H96PROPLUS_KDMC_mac-20171010(Shonk2).rar has the bootloader from aml_7.1_s912_q9377-S912_KDMC_mac-20171010.img
        booting fine and standby is working
        the orig firmware came from
        http://blog.geekbuying.com/2017/10/h...date-20171025/
          thanks for your work ,with shonk 1 ,can change launcher ?
            its the same as the 20170826 and 20171010 unbranded if the launcher doesnt use the wallpaper service you can
            if it does you cant
              Como lo instalais en el android ?? yo todo el rato error por USB_Burning_Tool y Burm Card Maker
                Downloaded aml_7.1.2_s912_q9377-H96PROPLUS_KDMC_mac-20171010(Shonk2).rar but was unable to unpack the rar file, error "can not open as an archive". Tried a few other rar files in the mega dir with same error. Tried to open the rar with other tools but same error. Only file i could open was aml_7.1.2_s912_q9377-H96PROPLUS_LP_(UNBRICK).txt. Anything wrong with the rar files?
                  they are rar5 not rar4 so whatever you use needs to support the latest rar5 (winrar does..)
                    Hi Shonk, thanks for your fast reply! That was the problem indeed. I guess I missed the introduction of rar5 4 years ago .
                      Hi
                      Shonk
                      Newbie here ... please sorry my english and if I do dumm questions
                      My first post here after last week read several posts...you "save" my Alfawise h96 pro+box with your cloud mega firmware, I used aml_7.1.2_s912_q9377-S912_KDMC_mac-20171010
                      I used that firmware on my box alfawise bought on August 2017 - ZH S912 TVBOX V2.0 (see photo)
                      Now my brother has one Alfawise h96 pro+ and want too update to 7.1.2 but box is from Oct 2016 CZ-S32-V2.2 (see photo)
                      So I am little confuse which firmware version have to use... if you can clarify I will appreciate a lot, thank you
                      His box has android 6 and dont know if is LPDDR (by version S32 V2.2 think not)
                      I will use usb burning tool 2.08 and one more question please... do I have to flash with bootloader ticked or not?
                      In future and for each box what I have to choose S912 branded or hcygood
                      Regards and thank you
                        CZ-S32-V2.2 is the same as mine
                        aml_7.1.2_s912_q9377-H96PROPLUS_KDMC_mac-20171010(CZ-S32-v2.2+CZ-S32-v3 Shonk).rar is fine
                        aml_7.1.2_s912_q9377-H96PROPLUS_KDMC_mac-20171010(CZ-S32-v2.2+CZ-S32-v3 Shonk2).rar is fine
                        aml_7.1.2_s912_q9377-H96PROPLUS_KDMC_mac-20170826.rar is fine
                        aml_7.1.2_s912_q9377-S912_KDMC_mac-20171010_H96PROPLUS_LOGO.rar is fine
                        aml_7.1.2_s912_q9377-S912_KDMC_mac-20171010 is fine
                        bootloader ticked is fine on CZ-S32-V2.2 as its a hcygood device
                        CZ-S32-V5 is also hcygood but is lpdrr3 so needs its own bootloader
                        yours (ZH S912 TVBOX V2.0) is a Wisdom device i think
                        I personally use this on my CZ-S32-V2.2
                        and replace the launcher with the h96 pro+ launcher and edit the build.prop to match the branded H96 Pro+
                          thanks for quickly reply... thank you very much for everything
                          I flashed on mine ZHV2.0 ... aml_7.1.2_s912_q9377-S912_KDMC_mac-20171010 is working (at least boot eheheh)
                            Hi
                            Shonk
                            flashed and working
                            Big thank you
                            Certainly you know superceleron rom, can I flash on both boxs? and which version SCV?
                              if it does you cant
                              Shonk thx for the "aml_7.1.2_s912_q9377-H96PROPLUS_KDMC_mac-20171010(CZ-S32-v2.2+CZ-S32-v3 Shonk2).rar" i just flashed it with sd card, but can you solve somehow this problem with launcher? i would like to use nova but it crashes... some flashable fix would be great, or flashable rom with nova only launcher.
                              best regards
