Thank you in advance
Firmware aml_7.1_s912_q9377-H96PROPLUS_KDMC_mac-20171010
Shonk sorry but it is not very clear your guide inside the file aml_7.1.2_s912_q9377-H96PROPLUS_LP_(UNBRICK).txt, if i have a Bick units model CZ-S32-v3 and i need to UNBRICK the step it is only to flash the iso aml_7.1.2_s912_q9377-H96PROPLUS_KDMC_mac-20171010(CZ-S32-v2.2+CZ-S32-v3 Shonk2).rar with burn card maker and follow the procedure usually ( insert the sd card, switch on the units when it is presset the reset button ..) or i need other image to flash before?
Hey SHONK, i have a h96 pro plus 3/32 box purchaced from banggood ,blue pcb with
CZ-S32-V5 29-8-2017 printed on it. it was bricked while i installed SuperSu and rebooted. it never show display after that , ony blue led blinking. i have tried sd card update method but it didnt worked. with usb burning tool process stucked at 2% or sometime at 4% . please suggest me which ROM did i flash to it ?? thanx.
Originally posted by maxim33 View PostHey SHONK, i have a h96 pro plus 3/32 box purchaced from banggood ,blue pcb with
Originally posted by Shonk View Post
I think you have a driver or cable issue. When someone says I flashed everything I always start back at beginning. Remove drive and the burning tool. From post in the amilogic tool section re install world cup driver and the tool.
change usb cord or try another one. I would try installing sc version of alf that is ddr3/ddr4 and see if that at least installs. Can deal with correct Wi-Fi once you actually burn image totally. Check temp settings in tool as well and set 10 degree hotter.
some times shows a pattern when all fail at 2 percent as all should produce different errors now and then.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostI think you have a driver or cable issue. When someone says I flashed everything I always start back at beginning. Remove drive and the burning tool. From post in the amilogic tool section re install world cup driver and the tool.
finally ,it had done !! today i get my new power adopter and when i plugged it in,and voila!! the "great superceleron"boot screan come to display. immedietlly updated to SCV7 and now everything works like a charm . thanks everybody for tips and sugestions. i think in near about all cases of "no display" faulty power adopter is the only major cause.
There are currently 3222 users online. 5 members and 3217 guests.
